Electrohome 8500 Flickering
UncleWill
Posted: Thu Jul 10, 2014 11:10 pm    Post subject: Electrohome 8500 Flickering
Okay, first REAL problem I have ever had with this set. Just happened a few minutes ago during a PlayStation session.
The tubes display at regular brightness, then much less, then back to normal. They actually turned off a few times as well before coming back. This has never happened before.
I do not think it is the cables, but will triple check anyway.
Thoughts? Power supply problems?
Posted: Thu Jul 10, 2014 11:14 pm    Post subject:
Before you do anything, do the test patterns do it? All colors?
UncleWill
Posted: Thu Jul 10, 2014 11:50 pm    Post subject:
Not sure about the test patterns. I did pull up the main diagnostic screen using the * button to see if they would be affected. They went out too.
UncleWill
Posted: Thu Jul 10, 2014 11:52 pm    Post subject:
It seemed like one of the colors would drop out or go to super low brightness. It would come back and do it again in maybe 5-10 second intervals.
The set is running right now with problems...yet.
Posted: Fri Jul 11, 2014 12:51 am    Post subject:
Does the picture 'zoom' in when it comes back, or just flash on and off'?
UncleWill
Posted: Fri Jul 11, 2014 5:44 pm    Post subject:
Flashed on and off
Posted: Fri Jul 11, 2014 6:47 pm    Post subject:
One of your VNB's might be bad. Causing the Spotikill circuit to kick in . If it defocused then it be a HV problem.
UncleWill
Posted: Fri Jul 11, 2014 11:26 pm    Post subject:
I don't think the focus went out. Any way to diagnose these firsthand? I have a spare set of parts, minus the neck boards and power supplies. Maybe if I caught it on video?
The diagnostics on the back read everything as A-okay.
