SONY HDIH-2000M lens set vs. HFQ900
ElTopo
Posted: Sun May 04, 2014 10:42 am    Post subject: SONY HDIH-2000M lens set vs. HFQ900
Anyone did a comparison between those two lens sets ?
Difference is that the Nikon lens set (9 inch LC) is motorized on the Sony CRT and it's said on different forums that the sharpness is great.
Could the Nikon lens set be mounted on every 9 inch LC CRT ?
ElTopo
Barco Cine 9 the one and only
Posted: Sun May 04, 2014 2:25 pm    Post subject:
Uhhh
Are those lenses for LC? Can they even be found anywhere since those projectors were 1987 vintage?
ElTopo
Posted: Sun May 04, 2014 4:22 pm    Post subject:
www.curtpalme.com/forum/viewtopic.php?p=97651
9 inch LC
Posted: Sun May 04, 2014 4:48 pm    Post subject:
Okay
The question then becomes Is the C element curvature same as HD10 series, and What about the bolt pattern
ElTopo
Posted: Mon May 05, 2014 4:37 pm    Post subject:
The seller says this lens set costs 50K Euro Shocked
Posted: Mon May 05, 2014 4:50 pm    Post subject:
Anyone believe that?
jbmeyer13
Posted: Mon May 05, 2014 5:06 pm    Post subject:
The Nikon lenses are all glass which would carry a hefty premium back in the day but $50K seems a tad high:-)
Posted: Mon May 05, 2014 5:29 pm    Post subject:
I don't know… Big, expensive lenses can get even more ridiculously expensive in low volumes. The lenses on the HDIH were servo focus if I remember correctly, so I could see the price getting out of hand pretty quickly.
Just as a frame of reference, check out the price on the Nikon 800mm f/5.6…
http://www.bhphotovideo.com/c/product/918849-REG/nikon_2205_af_s_nikkor_800mm_f_5_6e.html
Obviously that's a way higher-resolution lens, with fast focus servos and optical stabilization, but it's also much smaller, and made in a little larger quantity I'd imagine.
50k Euro back then does seem steep, though. If the projector was $20k, that would have put the whole kit north of 75k Euro with a screen, which seems excessive for those times. But, who knows?
jbmeyer13
Posted: Mon May 05, 2014 5:46 pm    Post subject:
Sony's first analog HD system was launched in 1984 (only available in Japan) and it was something like $300K+ and if it utilized that lens (or something comparable) then I guess it's entirely possible. I can't imagine them selling too many so the prices would have to be through the roof.
Posted: Mon May 05, 2014 8:12 pm    Post subject:
If I am correct forum member Noos@xp37+ here owns a Sony HDIH, and he also has a Marquee 9500 ultra, there was a thread where he summed pretty much about that machine with additional pictures too. He also found that this machine is extremely sharp (even the original tubes), but not surprisingly very bandwidth limited.
I seem to remember the C-element is not compatible with the HD10's C-elements, and even the lens mounting is completely different from the USPL lenses, so you'd be better to save those lc chambers too and fit in some modern chassis.
EDIT: found that thread:http://www.curtpalme.com/forum/viewtopic.php?p=378047&highlight=#378047
ElTopo
Posted: Tue May 06, 2014 12:58 pm    Post subject:
Thanks.
Total different lens and c-element.
I don't think it's possible to mount it onto a normal 9 inch lc tube.
