MacGyverismo
| Posted: Tue Feb 25, 2014 9:39 pm Post subject: Any hints on getting a working modeline? |
Hi all,
I'm trying to get the most out of my Barco 701mm, to that end I'm experimenting with finding the optimum resolution.
Unfortunately this is a rather frustrating process and I was wondering if you could give me some pointers.
The beamer has no problems with Pal 720x576@50(i/p), or 1024x576 for that matter. I'm running it at 1024x576@100i for now as it seems sharper than 50p, but the specs say it shouldn't even to that..
I'm trying to see if I can get it to lock at 1920x1080. I have the most difficulties with selecting the right vertical timing.
I wrote a few calculators to get some sort of timing, but I seem to have the best succes with trying to keep the relative timings the same as for the working PAL timing. So that the sync pulse widths should remain the same.
Now I would like to know what kind of magic makes the barco lock to a signal. Is it pulse width? Is it scan rates? voodoo?
any help would be appreciated
| Posted: Tue Feb 25, 2014 11:14 pm Post subject: |
Hello
You will need to live within the horizontal scan rate limits of the 701. 1080i is 33.5khz, 1080p is 67khz
| Posted: Tue Feb 25, 2014 11:29 pm Post subject: |
Is it a Data or a Vision 701mm?
MacGyverismo
| Posted: Wed Feb 26, 2014 7:47 am Post subject: |
I think it's a Vision 701mm, so H 15-50, V 37-210 if I'm not mistaken.
| Posted: Wed Feb 26, 2014 9:46 am Post subject: |
PAL is only via composite or s-video, its just a colour encoding type. It can be a number of different resolutions and V rates, but always 15.7kHz H rate.
Isnt the Vision model limited to 36kHz H rate? It should still do 1080i at both 50Hz and 60Hz
MacGyverismo
| Posted: Wed Feb 26, 2014 3:55 pm Post subject: |
| CasetheCorvetteman wrote: | | PAL is only via composite or s-video, its just a colour encoding type. It can be a number of different resolutions and V rates, but always 15.7kHz H rate. |
You're right, it's become a (confusing) habbit to refer to SD material at european framerates as PAL for me.. | Quote: |
Isnt the Vision model limited to 36kHz H rate? It should still do 1080i at both 50Hz and 60Hz |
I agree on 1080@50i, this is the modeline I tried for it:
Modeline test 67.49 1920 1963 1989 2432 1080 1082 1088 1110 interlace
Now this pixel clock is outside the range it accepts, but I am unsure how the interlace part of the modeline is interpreted. Will it halve the vertical resolution, or do I have to do this myself effectively specifying a 1920x540 modeline?
I've also halved the pixel clock, but in any case it wouldn't accept it.[/quote]
| Posted: Thu Feb 27, 2014 12:11 am Post subject: |
Youre obviously on progressive there, 67.49kHz is 1920x1080p at 60Hz.
Try doing 1280x720p at 50Hz and also at 60Hz and see if itll do that.
MacGyverismo
| Posted: Thu Feb 27, 2014 8:17 pm Post subject: |
| CasetheCorvetteman wrote: | Youre obviously on progressive there, 67.49kHz is 1920x1080p at 60Hz.
Try doing 1280x720p at 50Hz and also at 60Hz and see if itll do that. |
That's why I tried halving the pixel clock.
Anyway, I tried the following modeline:
Modeline test 29.99 1280 1308 1326 1621 720 721 725 740 interlace
No image.
I also tried without the interlace part, this was recognized as input, but the beamer didn't lock, so the image was scrolling badly. I suspect the vertical refresh isn't correct? as it didn't scroll sideways?
edit
Here's what puzzles me, after fiddling around with the vblank, and adjusting the pixel clock accordingly, I got it to produce an image at the following modeline:
Modeline test 48.63 1280 1308 1326 1621 720 760 764 1200 interlace
48630000 / 1621 / 1200 = 25, which would mean 50i
So this gives me 1280x720@50i but I'm using an awful lot of vblank..
now what makes it lock to this and not to other modes? completely puzzled...
| Posted: Fri Feb 28, 2014 12:19 am Post subject: |
Why i you doing this the hard way? What video card brand are using?
MacGyverismo
| Posted: Fri Feb 28, 2014 7:42 am Post subject: |
| CasetheCorvetteman wrote: | | Why i you doing this the hard way? What video card brand are using? |
I'm doing this the hard way, because I felt I wasn't getting the max out of it when I hooked it up to my laptop. Best I could do was 640x480 @ 60. So I decided to write myy own edid files, this allowed me to define my own resolutions but as osx required me to unhook the vga cable every time I wanted to try and use a different edid, I felt I was endangering my vga cable / port.
This made me setup a linux box with intel integrated graphics so I could just change resolutions on the fly as I am doing now.
So, in short; to get the maximum out of this beamer.
Also, once I find a resolution I think is best suited I will make several modelines for different refreshrates so I can watch all movies without stuttering.
| Posted: Fri Feb 28, 2014 10:34 am Post subject: |
Ok, youre going about it all the hard way. Just use Windows and its easy.
MacGyverismo
| Posted: Fri Feb 28, 2014 12:46 pm Post subject: |
| CasetheCorvetteman wrote: | | Ok, youre going about it all the hard way. Just use Windows and its easy. |
we might have a different perspective on that subject
| Posted: Fri Feb 28, 2014 9:38 pm Post subject: |
Its not a matter of perspective, the only reason Windows wont do this for you is operator error. If i wanted to go back to a chisel and stone tablet id stop using Windows and use one of the others... But i dont.
MacGyverismo
| Posted: Fri Feb 28, 2014 9:58 pm Post subject: |
The thing I'm trying to achieve, is to deliver a correct display format to the beamer, the software used is just a tool in this matter. Due to the way the beamer is connected ( rgbhv - vga ) the software can't help me with this, even if it wanted to. There is just no way for the beamer to instruct the computer what kind of signal it would like to receive.
So that makes it the operators responsibility, but the operator is confused because not all formats which should theoretically be within the limits of the beamer are accepted, which is the reason for my initial question
| Posted: Sat Mar 01, 2014 2:49 am Post subject: |
Beamer? Over here, youd be talking about a BMW...
Like i said earlier, if you use Windows, there are at least two programs i know of without searching that will do all this work for you very easily. All you need to do is tell it what res and refresh you want, select manual timings, or select from standard LCD timings or CRT timings. Its really quite easy to do.
If im understanding you correctly, youre trying to create an EDID for a monitor that doesnt exsist, there will be no EDID connection, so the computer may or may not see the device as a non plug and play monitor. If it sees it as plug and play, there should be a huge selection of available resolutions.
