Stigmators
416ray4538
Posted: Mon Feb 17, 2014 1:19 am    Post subject: Stigmators
9500
With focus at 100 , trying to make fuzzy circles as round as possible: in some zones the best I can get is fuzzy triangles
When the first clock was invented, how did they know what time to set it to?
No point being pessimistic; it probably would't work anyway.
Posted: Mon Feb 17, 2014 2:02 am    Post subject:
Not unusual. Does that tube have 2, 4 or 6 pole astig magnets on the tube neck?
416ray4538
Posted: Mon Feb 17, 2014 2:19 am    Post subject:
These tubes have 3 rings with knobs. I've read over the setup a few times and it sort of makes sense but I really don't want to open that can of worms if I don't have to. I know it has to be part of the procedure for a retubing and I'm sure you've done it over and over.
A little more detail maybe?
Posted: Mon Feb 17, 2014 2:50 am    Post subject:
Hello
The middle knob is triangle correction, with focus at 100 just turn it until the dots are round. It's that or replace the focus yoke
Posted: Mon Feb 17, 2014 3:07 am    Post subject:
Wait a sec, how many adjustments knobs are there? If the middle row doesn't have one, then you have 4 pole magnets. you most likely need 6 pole to get rid of the triangles, but finding the 6 poles is hard.
416ray4538
Posted: Mon Feb 17, 2014 2:53 pm    Post subject:
3 rings, 3 knobs
Posted: Mon Feb 17, 2014 2:59 pm    Post subject:
OK, you should be able to fix this with the middle ring as Tim says. What I'd do first is unplug the astig connectors from the astig board, so that the electronic astig adjustment is disconnected from each tube:
http://curtpalme.com/ElectrohomeMarquee_Layout3.shtm
reconnnect after you've set the astig magnets on the tube neck. Then retweak the electronic astig settings.
416ray4538
Posted: Mon Feb 17, 2014 3:20 pm    Post subject:
THe pic says 8500 only but anyway:
ceiling mount back to the screen, looking up at rear of pj the 3 plugs at my left each with 4 wires white, purple, blue, grey?
Posted: Mon Feb 17, 2014 3:26 pm    Post subject:
Same chassis, same location, same boards. Smile
Yes, those are them!
416ray4538
Posted: Mon Feb 17, 2014 3:38 pm    Post subject:
BTW Do you have your website hooked up to your alarm clock or you just couldn't sleep?
416ray4538
Posted: Tue Feb 18, 2014 12:51 am    Post subject:
OK
The middle ring helps. It turns triangles into almost circles. Quail eggs would be more accurate.
If I'm going down this road then OK let's go.
Do I have this right?
The knobs control how aggressive the affect of turning the ring is.
The 2 pole or flare ring (closest to the coils) is the most aggressive, the next 2 rings are "fine tuning?
In between making adjustments, switch menus and adjust focus up and down past the clear point and look for flares, shape of blob and flaring?
If the middle ring is triangle correction, why is it a fine adjustment from the 2 pole?
Look at the centre only? Very Happy
Posted: Tue Feb 18, 2014 4:50 am    Post subject:
Ray you may find this thread informative and interesting.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10647.html
416ray4538
Posted: Sat Feb 22, 2014 5:20 pm    Post subject:
This explains a lot too.
http://www.keohi.com/keohihdtv/experttips/guykuo/crt_astigmatism.html
416ray4538
Posted: Sun Feb 23, 2014 8:53 pm    Post subject:
The CPC magnets are clearly marked with white. There are 2 sets of markings but it's easy enough to go back to where they were.
Adjusting EM focus with the crosshatch and dots, changes the dots from little vertical lines to little horizontal lines.
If this sounds normal then the CPCs are gonna stay where they are ,but?????
Am I trying too hard or is this what I should get?
Posted: Sun Feb 23, 2014 9:06 pm    Post subject:
Hello
Set properly, the dots should be round at any focus value
416ray4538
Posted: Sun Feb 23, 2014 9:18 pm    Post subject:
Looking for dots with halos the best I get is triangles with a dot in the upper left( on screen)
Posted: Sun Feb 23, 2014 9:46 pm    Post subject:
For the CPC magnets only use the center of the screen for the best round dots you can get. the zones are done electronically .
Posted: Mon Feb 24, 2014 1:49 am    Post subject:
Try this
http://www.etechvideo.com/techtip9.htm
Your flare rings are the front knob
