Weak left side ?
jeffslife
Posted: Sun Feb 09, 2014 6:14 pm    Post subject: Weak left side ?
I have noticed lately that on certain films the left side of the audio seems weak. Not every film is this way but it seems like more than sound correct. It seems like I am hearing a much stronger right channel. To be fair I sit right of center but it seems to me its much louder, I barely hear the left side. I used a meter to set the volume levels and they are dead on. Anybody else notice this or do I have a problem ?
We are ALL job creators !
Posted: Sun Feb 09, 2014 7:34 pm    Post subject:
Have you had your ears checked lately, Jeff?
jeffslife
Posted: Mon Feb 10, 2014 12:20 am    Post subject:
My hearing is not great and it does change from time to time but not in the same evening. One movie sounds "balanced" and another doesn't. I checked to see if they were running different mixes, and it was the same mix. This seems to happen often.
jeffslife
Posted: Wed Feb 12, 2014 12:42 am    Post subject:
I couldn't take it anymore so I bumped up the left side by 2 decibels. According to the meter its way off but it sounds right.(finally)
Posted: Wed Feb 12, 2014 12:47 am    Post subject:
But, you said one movie would sound fine, and another you'd notice the problem. Aren't you just going to make the right speaker sound weak now if it sounds normal sometimes?
jeffslife
Posted: Wed Feb 12, 2014 1:48 am    Post subject:
Probably, I know its not a cure. its a patch. A very annoying patch. But I don't know what else to do.
Ron W
Posted: Wed Feb 12, 2014 2:15 am    Post subject: Re: Weak left side ?
You didn't indicate the source or the audio format and since the test tones are measuring fine, this could be a good place to start. It just might be the player or cable connections.
Posted: Wed Feb 12, 2014 2:53 am    Post subject:
Could it be a difference between dts vs Dolby digital vs SDDS vs whatever? Maybe your receiver doesn't decode them equally?
jeffslife
Posted: Wed Feb 12, 2014 5:47 am    Post subject:
Both movies played DTS HD MA 5.1 audio. One played a weak left channel ( to listen to it, not according to the meter ) one played fine.
