HDMI converter-> S-video or RGB
hiddink
Posted: Thu Jan 16, 2014 1:59 pm    Post subject: HDMI converter-> S-video or RGB
Hello,
I have a HDMI converter which I use for connecting my iPad to my Sony CRT-projector. I can either choose to connect via s-video or RGB from the converter. The projector either accepts S-video or the 5x BNC connection (rgbvh).
Via which route can I expect the best results? So far, s-video works quite well but do not know if via rgbvh I can achieve better results?
Thanks in advance for your advice!
-brt
Posted: Thu Jan 16, 2014 3:16 pm    Post subject:
RGB will give you a far better image.
hiddink
Posted: Thu Jan 16, 2014 5:55 pm    Post subject:
Thanks for your answer, I've got this converter from deltaco:
http://www.hardware-store.dk/deltaco-signalkonverter-fra-hdmi-v1-3-19-pin-hun-til-kompositvideo/prod_9137.html
and I use it with S-video...but what cables do I need to transfer the converted HDMI-signal from rgb (composit?) to rgbvh, that is from 3 out to 5 in???
Thanks again for your help!
Regards,
-brt
