Uh oh New SVS subs are out !!!!!
Posted: Thu Jan 09, 2014 11:10 pm    Post subject: Uh oh New SVS subs are out !!!!!
Well at this time last year actually two days from now I ordered Dual PB1000's and I love them.
But I got a news letter form SVS the other day abut the new 2000 series. I knew about their
full credit refund if you upgrade with in a year. I thought i passed it, but I found the invoice and it
was on the 11th. So I bit the bullet and ordered the dual PB2000's
I spoke with Ed Mullen and he seemed more excited about me getting the subs that I am!!
He said these will double the performance of the PB1000's in my large 4000 cu ft room.
**Frequency response graph does not denote maximum output capability.
*2-meter ground plane away from reflective structures (quasi-anechoic).
*17-260 Hz +/- 3 dB.
*Expect 2-3 Hz deeper extension in small to mid-size rooms.
*FR graph does not denote maximum output capability.
FR from 17hz to 260
SVS 12" High Output Driver
Designed from scratch—and optimized through exhaustive testing until it delivered unprecedented performance we were after—the all new 2000-series driver does us proud. Matched and maximized to its Sledge amplifier, it effortlessly delivers the STA-500D’s precision, dynamic flexibility and raw punch. The result: the all-new driver delivers higher output, improved linearity and lower distortion. Which means loads of clean, precise, deep powerful bass for your movies and music.
All-new, exhaustively tested design.
Computer FEA-optimized motor for even lower distortion.
Heavy-duty voice coil for extreme power handling.
Upgraded suspension for improved linearity and control.
Lightweight aluminum cone delivers high efficiency.
Rubber surround for excellent durability and long-life.
Very Happy
jeffslife
Posted: Thu Jan 09, 2014 11:39 pm    Post subject:
SWEET !!!
We are ALL job creators !
Posted: Thu Jan 09, 2014 11:55 pm    Post subject:
Yeah SVS is a sweet company.
The way the refund works is your suppose to return the subs before the year date. But ed let me slide and said I just order the new subs and pay in full. He said he'd even let me set up the new subs under their 45 day trial period . If i don't want them I send them back and pay shipping. If i do decide to keep them, which I know I will, i send back the PB1000's and they credit my CC the full price I paid for the PB1000's
So for little money you could actually upgrade each year of you wanted to!!!
Posted: Fri Jan 10, 2014 12:23 am    Post subject:
Cool! Pretty reasonable priced as a pair. Let us know what you think when you get them set up!
Whatever you do, don't run all four at the same time. Wink
Posted: Fri Jan 10, 2014 12:25 am    Post subject:
I will and i would never do something like that Steve!! Wink
And if your at CES go to thier booth and listen to them foe me Wink
Posted: Fri Jan 10, 2014 12:35 am    Post subject:
I'm not at the show. Sad Somebody has to stay back and hold down the fort and actually get some work done. Wink
I'm sure they'll be very impressive.
Posted: Fri Jan 10, 2014 12:38 am    Post subject:
Really! You'd rattle the neighbors. You'd be as bad as Cliffy!!
Posted: Fri Jan 10, 2014 12:46 am    Post subject:
I was thinking more along the lines of the fact that he wouldn't be able to send the others back… But, yes - four subs would be capable of some pretty healthy SPL.
Posted: Fri Jan 10, 2014 4:49 pm    Post subject:
?? I'm missing something. Why would running all 4 (assuming you had amps to do it) prevent you from sending back one pair?
Oh -- do you mean it would just be so freakin' awesome that he wouldn't be able to part with any of 'em? Laughing
Posted: Fri Jan 10, 2014 5:54 pm    Post subject:
Precisely. Wink
Posted: Sun Jan 12, 2014 8:01 pm    Post subject:
wow, you guys are actually running normal out of the box sub-woofers? I thought for sure the nutters on this forum would all build their own infinite baffle set-ups? Crabb didn't you post yours on AVS long time ago? 4 x 12" drivers with custom 2x 4 frame into and adjoining basement space?
I remember someone actually cut a hole in the Oak floor of their upstairs living room and used that as the baffle? Shocked
Posted: Sun Jan 12, 2014 8:07 pm    Post subject:
the 1K's were $500. each and the 2K's are $1000. each, so even with full trade in credit it's still a grand for the pair. Not exactly cheap but people piss away a lot more than that on HT's
I paid $1K for my single Quad 12" SW with 300 watt amp, but it's a musically accurate sub as opposed to just a giant boomer
Posted: Sun Jan 12, 2014 8:56 pm    Post subject:
Don't know who you're thinking about, but it wasn't me building IB. That sh*t is crazy… Cutting holes between conditioned and unconditioned spaces… Lord, no thanks.
I did build my own subs, because I could build two high-performance subs for less money than one decent commercial mid-range sub. It takes some work, but you can end up with some truly amazing results for not a lot of money.
Personally, the IB approach holds zero appeal to me. I have a wife and two kids, so isolation is far, far more important to me than ultimate performance. While I completely respect what others do with IB setups, I have no interest in sinking thousands of dollars into a setup that requires extensive modifications to the structure. I just don't like the approach.
The subs I built are flat to well below 20hz in-room, and clean well into the SPL range that matches my mains. If I drop down from reference level a little, then I have good output down into the 15 hz range. They're sealed alignments using Dayton 15-inch reference drivers, really good amps, and an EQ, so they're excellent for HT, but I also load a different EQ setting into memory, and they're very musical.
While it's far from a "high-end" sub setup, it's very respectable, and I spent almost a third of what most people spend on one really high-end sub like a Seaton Submersive or JTF Captivator.
Posted: Mon Jan 13, 2014 12:17 am    Post subject:
All I know is that Once you buy an SVS sub I think you'll be a customer for life.
Cant wait to set up the new sub's. I will most likely also co locate the PB1000 on top of the PB 2000's just to see how it sounds
in that type of set up. Wink
Posted: Sat Jan 25, 2014 2:12 am    Post subject:
Very Happy
Posted: Sat Jan 25, 2014 2:19 am    Post subject:
So tell us Nash, does size really matter? Very Happy
Posted: Sat Jan 25, 2014 2:28 am    Post subject:
Wont know yet. Have to let them warm up, been in my truck for 5 hours.
Aslo I am beat so I won't hook them up for a day or so. have family obligations tomorrow and sunday.
Ed Mullen from SVS will be in buffalo for some meetings on Feb 4th, trying to get him to Stop by The Odyssey
for lunch.
Posted: Wed Jan 29, 2014 5:27 pm    Post subject:
Moooowwaaaaaa!!!!!!!
This set up is Sweet!!!!!
I may not send the PB 1000's back.
Very Happy Very Happy
HK-Steve
Posted: Wed Jan 29, 2014 6:05 pm    Post subject:
Center channel needs a little beefing up.....
Looks awesome.
Posted: Wed Jan 29, 2014 6:11 pm    Post subject:
Looks awesome.
What I might do Is keep a PB 1000 and place it where the Amp is and put the center on top and run the Center line level to the PB 1000 and cross it over at 80 hz. So the center gets the Deep base it deserves.
