Barco CRT types
tse
Posted: Thu Dec 19, 2013 10:29 pm    Post subject: Barco CRT types
I have a friend asking about Barco CRTs that have some type of dial or knob adjustment on them. Probably for schiemflug. The numbers are:
R7635722K
R7635725K
R7635726K
It seems that they cut the old tubes from the housings to replace and forgot to note the orientation so the new ones could be installed correctly. Any help on this much appreciated.
Scott
Thomas Jefferson
winny
Posted: Thu Dec 19, 2013 10:38 pm    Post subject:
Something tells me Decibel will be here any minute with an answer.
Melifluonze wrote:
Hulio
Posted: Thu Dec 19, 2013 11:15 pm    Post subject:
Those are spare LUG's for BR909.
Not sure about the orientation but unless the housings are for 90° configuration ( vertical split pack ), they can't be wrong mounted. Scheimpflug adj. up.
Posted: Thu Dec 19, 2013 11:57 pm    Post subject:
Scott, with the spring thing Scheimpflug adjustments facing upwards, the opening of the LC housing facing you, the anode lead of the tube needs to face right. If it faces left, the tube will be rotated 180 degrees, and you can't fit the video amp/CRT socket on it.
Hulio is incorrect, you can mount the tube the wrong way around.
Do ask the customer if they are tube housings for 919 sets, which rotate the tube metal frame 90 degrees from the front. I've got some 919 sets here, and can take a pix of the housing.
Also make sure the plastic spacers are in front of the tube between the tube and the housing.
tse
Posted: Fri Dec 20, 2013 12:11 am    Post subject:
Curt,
Thank you much. That is exactly what I was looking for. That is a kind offer to take some pics of the housing. If not too much trouble that would be nice. I owe you one. Let me know if there is anything I can do for you.
Merry Christmas to you and all the forum members!
Thomas Jefferson
Decibel
Posted: Fri Dec 20, 2013 9:35 am    Post subject:
Here the boxes of LUG's
Here a blue LUG, you can see the scheimpflug adjustment.
Domenico (Barco fan!)
tse
Posted: Fri Dec 20, 2013 1:23 pm    Post subject:
Domenico
Thank you very much. That is very helpful.
Have a Merry Christmas!
Scott
Thomas Jefferson
