the big E
| Posted: Mon Dec 09, 2013 9:41 pm Post subject: Dwin no picture from signal |
New to me dwin from curt got the set as a backup and while trying it out I can't get it to lock to a signal
Is there something I am missing or is there something else I need in the video chain to get my video equipment to work with the dwin??
I plan on maybe ceiling mounting it once I figure out why I can't get it to lock on a source
| Posted: Mon Dec 09, 2013 10:29 pm Post subject: |
Negative sync for the 700 only, you may need an Extron 202xi or 203, and you need to do a signal entry before you can unlock the convergence settings, but you should see an image regardless whether the memory location is set or not.
the big E
| Posted: Tue Dec 10, 2013 12:24 am Post subject: |
| Curt Palme wrote: | | Negative sync for the 700 only, you may need an Extron 202xi or 203, and you need to do a signal entry before you can unlock the convergence settings, but you should see an image regardless whether the memory location is set or not. |
Which one is a better choice?
Not going to mess with it till I can feed it a signal as I don't want to screw up a setting
I knew it is negative sync but why won't it sync to a computer??
| Posted: Tue Dec 10, 2013 12:27 am Post subject: |
Your computer is probably putting out postive sync. the 203 is a newer unit.
the big E
| Posted: Tue Dec 10, 2013 12:30 am Post subject: |
| Curt Palme wrote: | | Your computer is probably putting out postive sync. the 203 is a newer unit. |
I figured going to find the 203 version since its newer
I can't believe how quiet the machine is LOVE that kinda makes me wish my marquee was that quiet
the big E
| Posted: Tue Dec 10, 2013 2:40 am Post subject: |
Curt is it possible I can run HD signals through a dwin trans scanner?
I looked into one and it has the sd inputs along with rgb looks like it would be a good choice but want to be sure
the big E
| Posted: Tue Dec 10, 2013 3:58 am Post subject: |
btw curt huge thanks for the setup/user manual
the big E
| Posted: Tue Dec 10, 2013 5:09 pm Post subject: |
Ah thanks for clearing that up
Just wondered if it would work now to get extron 203
Any tips on mounting the trailing mount so I don't have to worry about it coming loose?
I plan on making a hoist using four pulleys and cable to lift it up and down from the mount easier so I can have for on the to showings
the big E
| Posted: Wed Dec 11, 2013 6:27 am Post subject: |
Curt I looked at the eBay link you provided I hope it stays cheap if it does I am all over it
I wonder would a transcanner work for the non HD stuff I have like my older game systems??
I do have the decoder card in my marquee for non HD/rgb stuff(really would like to get a switcher though)
