| Posted: Sat Nov 09, 2013 12:34 pm Post subject: |
You should absolutely be using the RGB-HV input depending on the projector, why are you use the HDMI input? The PC will be more cable of the D/A conversion than whatever else youre using.
Having said that, the only reason youre not getting a lock is cause the timings are wrong, id almost bet youre using nVIDIA and newer drivers, around the 320ish mark. They have adjusted the timing on the newer drivers, and the sync width is too small.
