does the original hdfury have any issues with crt projectors
benareeno
Posted: Thu Oct 10, 2013 8:57 pm    Post subject: does the original hdfury have any issues with crt projectors
If I am using a Barco or NEC, will the original Fury work properly?
synch wise and centering...would all be ok?
Ben
Posted: Thu Oct 10, 2013 11:58 pm    Post subject:
I've had no issues.. BUT YOU NEED THE POWER SUPPLY FOR THE FURY!!! Smile
Posted: Thu Oct 10, 2013 11:59 pm    Post subject:
Oh actually wait.. one thing. the Fury 1 has no selectable sync, and a number of HD sources put out positive sync via the HDMI cable, so yes, you may have issues with sync. You may need a sync inverter after the Fury1. the GammaX will do it, or an Extron 202xi or 203 will do it too.
benareeno
Posted: Fri Oct 11, 2013 3:55 pm    Post subject:
I would assume that a lumagen could switch the sync..?
I thought the original fury didn't use a power supply..but I don't know that for sure.
fragzero
Posted: Fri Oct 11, 2013 4:56 pm    Post subject:
Yes a lumagen can change the sync.
There are known issues with a standalone HDFury, i'd find one just to be sure!
Posted: Sat Oct 12, 2013 1:07 am    Post subject:
All the Furys had power supplies... MANDATORY... save for the gamer version.
Posted: Sat Oct 12, 2013 1:17 am    Post subject:
Yes, the only componnents that outputted enough power for the HDFury were PS3 Phat and Xbox 360 Elite, I also found one other Samsung tuner that would drive it. Everything else I tried wouldn't work. Get the power supply.
Here's a hint: You can get the charging cord for the Nokia cell phone and reverse the polarity on the wires and use that for the HDFury. DO NOT try powering it without making sure the polarity is right. (-) Negative on the center pin.
