NEC 9PG+ powers on & then shuts down after a few secs.
Goto page 1, 2, 3  Next
Sunshinehere
Posted: Sat Aug 24, 2013 7:24 pm    Post subject: NEC 9PG+ powers on & then shuts down after a few secs.
Hi everyone,
I am new to this great forum.
Since 13 years I own a NEC 9 PG+ PJ.
Thanks to all the advice on the net & Curt's pages I managed to get a nice picture in 1080i and could enjoy hundreds of movie hours with it.
However last weekend while watching a movie the vertical edges of the picture started to wobble a little.
Then suddenly the PJ shut down. (Movie 43, perhaps the PJ was shocked by it too...)
Shocked
Turning it on resulted in the following symptoms:
1. Fans start to turn, 2 red LEDs light up on the board
2. after 2-3 secs the PJ shuts down
3. it jumps back to 1. automatically and would do that constantly if not interrupted.
On the Display at its back there are only two dashes, no other error code.
The CRTs don't light up either.
Thanks to anyone who can give a hint what to look for,
Thomas
Posted: Sat Aug 24, 2013 9:26 pm    Post subject:
My guess is that the power supply is bad. Very hard to repair, not worth sending in due to postage costs, but I've got good working spares at $125 incl shipping. In fact, I'm scrapping about 5 NEc PG sets this weekend, and I can send you a pile of boards for the cost of shipping if you want on top of the power supply.
you could also try disconnecting the focus and convergence board power connectors (5 or 6 pin large connector on each one of those boards, to see if that's causing power supply shutdown, but with two red LEDs on the deflection board usually indicates a fault in the power supply, especially since you have no error codes on that back LED display.
Where are you located?
Posted: Sun Aug 25, 2013 7:17 am    Post subject:
Thomas, where are you from?
Sunshinehere
Posted: Sun Aug 25, 2013 5:02 pm    Post subject: Disconnected C & F Boards- same symptoms
thanks for your quick reaction.
I did like Curt proposed and disconnected the two boards, then turned the device on- no change in what happens.
It seems then to be power supply.
I live in Germany.
@Curt,
thanks for your offer.
I am not confident enough to do some soldering work should that be needed.
I already caught myself a few years ago with the thought to kick out the PJ as it is quite noisy.
Now with this incident perhaps I should say goodbye to the CRT- PJ era.
A tried a DLP PJ at a friends house but seem to be susceptible to the infamous Rainbow-Effect....
I'll think about it...
Confused
Kind regards from Germany,
Thomas
Posted: Sun Aug 25, 2013 9:42 pm    Post subject:
Its all plug in for every board and the power supply on a PG Thomas Wink
Posted: Sun Aug 25, 2013 10:20 pm    Post subject:
Actually, make that $175 considering you're overseas from me. There's no soldering involved in replacing the power supply.
Posted: Sun Aug 25, 2013 10:51 pm    Post subject:
Check voltages first, id say in Germany itll be 230/400v mains.
Sunshinehere
Posted: Mon Aug 26, 2013 3:59 pm    Post subject: 230 V@ 50 Hz
Hi Case,
yes: 230 V ± 10% at 50 Hz.
Using the wrong voltage might result in a nice living room firework though Wink
Regards, Thomas
Posted: Tue Aug 27, 2013 3:58 am    Post subject:
I think you can change them internally, Gjaky has looked into this i think.
Tinman
Posted: Wed Aug 28, 2013 12:11 am    Post subject:
The power supplies can be changed internally. It involves a jumper or 2 and ideally changing the values of the filter network on the input. It's in the manual.
This space for rent.
Posted: Wed Aug 28, 2013 6:38 am    Post subject:
Thanks for claifying Tinman Wink
Sunshinehere
Posted: Thu Aug 29, 2013 7:00 pm    Post subject:
Yes, thanks for the clarification.
I found a page where they said that too. However the mentioned that in relation with the NEC XG series.
That means I have to decide, whether I want to invest some bucks into the NEC, bearing in mind that it might not work again, or break down with one of those capacitor issues.
Well, I think I'll end the CRT PJ era. (my wife will be happy about that too..). That was/ is a fascinating technology with a lot more soul to it than the digital PJs.
I want to thank all of you for your time & advice and wish you all happy watching with your sets.
Kind Regards from Germany,
Thomas
Posted: Fri Aug 30, 2013 7:29 am    Post subject:
Thomas, buy yourself a Cine 9 or an XG Wink
hansilili
Posted: Tue Oct 22, 2013 7:20 am    Post subject:
Thanks Thomas, for letting me have your set. Made it hime safely.
Cheers
hansilili
Posted: Tue Oct 22, 2013 7:30 am    Post subject:
Nice work Thomas Smile
Sunshinehere
Posted: Tue Oct 22, 2013 9:52 am    Post subject: Projector is gone.....
Thanks Case.
I am glad you made it home safely, hansilili
Now there is a gaping void at the ceiling *sniff*
Thomas
Posted: Tue Oct 22, 2013 10:41 am    Post subject:
Space for that XG mate Wink
Sunshinehere
Posted: Tue Oct 22, 2013 11:12 am    Post subject:
hmm. I think my wife would insist on a divorce ....
Then I am in trouble because the XG does not fit into the shack that I would be able to afford Very Happy
hansilili
Posted: Tue Oct 22, 2013 12:00 pm    Post subject:
I can donate a ceiling bracket and remote control if needed Mr. Green
Posted: Tue Oct 22, 2013 2:44 pm    Post subject:
Garbage!! Even though I have 7 acres of land, I live in a very small 1 bedroom home, 6m x 7m, and I have an XG installed in my bedroom, and a Barco CineMAX in my lounge room.
No more excuses!! Laughing Laughing Laughing
Page 1 of 3
