Test patten Larger than Video Image (Marquee 8000)
sarahstaar
Posted: Sun Aug 11, 2013 11:04 am    Post subject: Test patten Larger than Video Image (Marquee 8000)
When i put up a test patten / grid for convergence up the test patten is wider than my screen by about 2 and a half squares.
When i play a DVD or Blue ray the image fits perfectly on the screen? why is this ??
Is my projector incorrectly set-up??
My projector
Marquee 8000 with all the HD Mods by DraganM.
I am also using the Marquee VIM-FULLHD v3 HDMI 1.3 Input Card.
I am running the projector at 720P 50hz
DVDO iScan Duo Video Processor
Posted: Sun Aug 11, 2013 1:26 pm    Post subject:
The grid is the projectors internal convergence pattern right.?
If so its right.. And no need to worry at all.
Its just the H & V total pixels from the source whos bigger than the actual image resolution.
So your raster / grid patter have to be bigger than the image. Thumbs Up
Posted: Sun Aug 11, 2013 1:30 pm    Post subject:
That is normal for a marquee. Always use an external pattern to setup Geometry and convergence. The only time it matches is if the timings of the source and the internal pattern generator are matched.
sarahstaar
Posted: Mon Aug 12, 2013 8:08 am    Post subject:
Thanks...
I have just re-converged my projector using a grid pattern from my DVDO iScan Duo.
