Pioneer VSX-821-K - Acts like it works but NO sound - Solved
Jeremy112
Posted: Sat Jul 13, 2013 7:25 pm    Post subject: Pioneer VSX-821-K - Acts like it works but NO sound - Solved
mac, this is a bit off the wall from the Yamaha I have yet to get back around to, its a Pioneer VSX-821 and the issue it originally had was a distorted right channel, I later found that the amplifier PCB itself had been badly burnt up. Looked to be from a shorted output on the front right channel...
Anyway, while repairing the amplifier, I noticed that a VSX-521 amp is literally identical in specs, performance, design and fit. I went ahead and pulled the good amp from the 521 and threw it in the 821, well everything LOOKS like it works, all relays click on that should, functions all work, but I get no sound at all from any channels on the speaker outputs.
Now I thought maybe it was the FM tuner so I tried a different input, no dice. Well I had to disable the damn demo mode on it since it was driving me nuts, and while I was in there I went to the speaker setting to adjust the channel level, and as you probably know the sound that the amp puts out while adjusting the channels should be there, but the setup sound for adjusting the MCACC or channel levels isn't heard either.
So, basically, no matter what, there is NO sound. The amplifier is just fine, checked it over, its not running hot, in fact, its not getting any signal it seems since its running rather cool, almost luke warm.
So I call upon your wise words of wisdom again mac, in hopes you'll lead me to the right path Razz
Posted: Sat Jul 13, 2013 7:55 pm    Post subject:
I think I already know the answer to this but let me look up a few things so I can be more specific.
Posted: Sat Jul 13, 2013 8:43 pm    Post subject:
Did you change anything else other then the AMP assy? How many boards in that assy?
Jeremy112
Posted: Sun Jul 14, 2013 1:51 am    Post subject:
Just the amp assy, and there is only one large board on the amp assy
Posted: Sun Jul 14, 2013 2:21 pm    Post subject:
Did the 521 amp work before you pulled it out?
Jeremy112
Posted: Sun Jul 14, 2013 8:11 pm    Post subject:
Yes it did mac, nothing wrong with it.
Posted: Sun Jul 14, 2013 9:12 pm    Post subject:
Well if before the swap the 821 all channels worked except for a distorted 1 and the 521 also worked fine before the swap and after the swap there are no channel outputs......... then you f*ck*** something up.
The 821 and 521 amps are identical...... and I mean, "IDENTICAL" including each and every part. Even the complete board replacement part number is the same.
So swap them back and see which one doesn't work now.
Jeremy112
Posted: Mon Jul 15, 2013 2:21 pm    Post subject:
Mac, I should have detailed that the receiver stopped putting audio out with the original 821 amplifier. It was cutting in and out on its own so I lifted the front of the receiver and let it drop onto the counter top, the audio then ceased to function.
I figured it was the 821s original amplifier since the main bus foils were burnt through like paper. Obviously that isn't it since as you said the 2 boards are identical.
I'm sure I f*ck*** something up due to the "drop" test, I'm almost willing to bet its something on the bottom of the motherboard of the receiver, since the amp mainly connects to that.
Posted: Mon Jul 15, 2013 3:00 pm    Post subject:
Ah ha...... leaving out pertinent information..... shame on you.... Laughing Laughing
Did you want to troubleshoot then? I do have some time today.
Jeremy112
Posted: Mon Jul 15, 2013 6:42 pm    Post subject:
Yeah if you're willing we can do some work on it. I don't have anything else on the table for the time being so why not Very Happy
And yeaaaa I know, but who likes to admit such details Razz
Posted: Mon Jul 15, 2013 7:31 pm    Post subject:
First thing, on that amp board is find connector CP403. DMM on DC and receiver turned on. Pin 8 for ground lead. Positive lead Pin 5 for - rail and Pin 2 for + rail. Let me know what you get.
Jeremy112
Posted: Tue Jul 16, 2013 2:00 pm    Post subject:
Well... I apologize about the delay mac, but curts site was down or something, I couldn't access it to reply with my findings so I gave up and went to calibrating a TV Razz
Anyway, the readings were +56.25v and -56.25v with pin 8 as ground. Sorry it took so long! Embarassed
Posted: Tue Jul 16, 2013 3:23 pm    Post subject:
Ok, 2 question.
1) Are you sure the speaker output relays are closing. I know you said they were I'm just double checking.
2) Did you ever put together that signal tracer I told you about?
Jeremy112
Posted: Tue Jul 16, 2013 3:50 pm    Post subject:
Yes to #1, and no to #2 Embarassed I know I know, I'm bad Razz
Posted: Tue Jul 16, 2013 3:59 pm    Post subject:
Ok. Lets check something else first and if it checks ok then you may have to put it together.
Locate the audio board. Should be the one with the audio inputs. It should have an ic400 on it. There should be a connector CP402, probably where it connects to another board. You need to check for 2 voltages there.
Use pin 5,8 or 10 for ground. DMM on DC. Turned on, pin 4 should have +6.8v and Pin 6 should have -6.8v. Let me know.
Jeremy112
Posted: Tue Jul 16, 2013 4:31 pm    Post subject:
Mac,
I thought just for the heck of it because it DID have audio output before the "drop test" that I would pull all the connections and reseat them....
... it actually worked! Neutral I never get that lucky! I did another "drop test" which is only the front of the unit being lifted 3" from the counter, and it didn't cut out so it must have been a loose connection.....
Makes me feel somewhat dumb Laughing
Posted: Tue Jul 16, 2013 4:33 pm    Post subject:
It's no fun when they are to easy..... Laughing
Jeremy112
Posted: Tue Jul 16, 2013 5:23 pm    Post subject:
You're telling me, lol. Don't worry I have a few here that I'm sure will work both of us over Wink
