X-Rite DTP-94 for Calibrating Projector or Something Else
nszzya
Posted: Tue Jun 18, 2013 2:21 pm    Post subject: X-Rite DTP-94 for Calibrating Projector or Something Else
Have a 6 year old (?) X-Rite DTP-94 used for computer monitor calibration. Looking to calibrate front projector in HT (Sony VPL-HW50ES). Should I upgrade to PRO and buy the Chromapure software for about $330 ($150+180) or get the Eye One Display 3 with Chromapure for $419? Will the difference be worth $90? How about the Display 2 with the Color HCFR software? Other recommendations? Thanks for any advice!
Posted: Tue Jun 18, 2013 3:05 pm    Post subject:
I would go with the Display 3 (or Display 3 PRO) with ChromaPure. The Display 3 is so much faster reading and accurate.
Your DTP-94 is old enough that you'd need to have it calibrated anyway and I just don't think it's worth it.
See:
http://www.curtpalme.com/ChromaPure_EyeOneDisplay3.shtm
nszzya
Posted: Wed Jun 19, 2013 4:10 pm    Post subject:
Thanks for the advice. Can the Display 3 PRO be used with basICColor to calibrate a Mac display?
Posted: Wed Jun 19, 2013 4:17 pm    Post subject:
The Display 3 and Display 3 PRO meter are the same physical meter. The "PRO" version includes software based lookup tables for 10+ display types to make the meter more accurate when using ChromaPure. When using any other software (includic basICColor) the increased accuracy does not work as the other software doesn't know how to read/use these software lookup tables.
The increased accuracy is done via software to ensure that the meter can be used with other software as usually changes to the meter itself means it no works with any other software other than the one it was originally sold with.
More information on the "PRO" feature here: http://www.curtpalme.com/ChromaPure_EyeOneDisplay3.shtm
See the section called "What is the EyeOne Display 3 PRO?".
