incova
| Posted: Sat May 11, 2013 6:55 pm Post subject: How large a room do you need to blend 2 projectors? |
Hi guys, I am thinking of the future here, or dreaming maybe lol, how large a room would you need for a pair of PJs blended and what would be the optimal screen size in metric?
the less I know.
| Posted: Sat May 11, 2013 7:07 pm Post subject: |
Hello
The cool thing about edge blending, besides obscene light output, is the very small footprint, since your throw ratio is 1.0 to 0.95 depending on the screen aspect. I sit behind two table mounted 9500s filling a nine foot screen width in a seventeen foot depth no problem.
| Posted: Sat May 11, 2013 7:20 pm Post subject: Re: How large a room do you need to blend 2 projectors? |
| incova wrote: | | Hi guys, I am thinking of the future here, or dreaming maybe lol, how large a room would you need for a pair of PJs blended and what would be the optimal screen size in metric? |
MET-A-RICK what's that?
Tim, how far are your projectors from the screen? ( please answer in cubits, decimal fathoms are acceptable also )
| Posted: Sat May 11, 2013 7:28 pm Post subject: Re: How large a room do you need to blend 2 projectors? |
| AnalogRocks wrote: | | incova wrote: | | Hi guys, I am thinking of the future here, or dreaming maybe lol, how large a room would you need for a pair of PJs blended and what would be the optimal screen size in metric? |
Tim, how far are your projectors from the screen? ( please answer in cubits, decimal fathoms are acceptable also ) |
Less than a furlong! About 100 inches actually for 107" screen width. Blending is suited for screen widths of 100 to 180 inches. Gino was using one of the larger screen sizes around the top of that range. Gino?
incova
| Posted: Sat May 11, 2013 8:04 pm Post subject: ye |
this is why I didnt go for chains furlongs etc funny guys! lol
the less I know.
incova
| Posted: Sat May 11, 2013 8:07 pm Post subject: size |
What was the size of Ginos screen?
the less I know.
the big E
| Posted: Sat May 11, 2013 10:03 pm Post subject: Re: How large a room do you need to blend 2 projectors? |
| Tim in Phoenix wrote: | | AnalogRocks wrote: | | incova wrote: | | Hi guys, I am thinking of the future here, or dreaming maybe lol, how large a room would you need for a pair of PJs blended and what would be the optimal screen size in metric? |
Your picture makes me want to do a setup like this how would I do this cool setup?
the big E
| Posted: Sat May 11, 2013 10:56 pm Post subject: |
| Nashou66 wrote: | 4.1148 meter screen but for now only using 3.5 meters till I upgrade to 9 inch tubes.
Nashou |
So jelious
| Posted: Sun May 12, 2013 8:14 am Post subject: |
Nashou |
I love the screw drivers and other tools next to the projector
What material did you use for the screen?
| Posted: Sun May 12, 2013 1:15 pm Post subject: |
Even the smallest dumpster will hold two projectors with plenty of room to spare
_________________ Chip
mc86
| Posted: Sun May 12, 2013 4:33 pm Post subject: |
To the OPs Q regarding how large a room size do you have to have for a blend...seems to me this is backwards. That is, seems like the question should be: How large does a room and screen have to get before a blend is desirable for a given PJ? This gets at brightness, spacial resolution/visual acuity, viewing distance, viewing angles (horz and vert), and other stuff that depend on room geometry. Sitting distance vs seating distance, primarily.
Without having worked the out what the brightness or spacial resolution would be, I'd *guess* the answer for CRTs is that each inch of tube can support an additional 20" (0.5m) width. Thus:
7" machine shouldn't do much bigger than 80" (2.1m) wide [and cannot do less than ~45" (1.05m)?]
8" machine shouldn't do much bigger than 100" (2.5m) wide [and cannot do less than ~50" (1.25m)@8ft (2m) throw?]
9" machine shouldn't do much bigger than 120" (3m) wide [and cannot do less than ~60" (1.5m) @9ft (2.25m) throw?]
Assuming this rough guesstimate works OK, the room DEPTH (sitting distance) would be determine based on trying to achieve something like a 30 to 36 degree viewing angle. There is a nice set of charts here:
http://www.avsforum.com/t/1004723/chart-distance-x-screen-size-standards-smpte-and-thx
Taking my room as an example, distance from screen surface to seating area is just under 14ft (4.2m). My 80" (2m) screen is 14ft away and this gives a 26degree angle. It is so small as I have a 7" machine. I'd like 100" (2.5m) screen to get to 33degrees -- a 9" machine ought to do a 100" screen really well and an 8" machine OK.
Most on here will agree with the above, BUT will say they want things brighter! This is nothing to say about maintaining the correct vertical viewing angle and the amount of keystoning on the tube face that a closer mounting (and vertical angle) would demand (without raised seating). In my case, a blend also increases the resolutions I can support.
A 7" machine can handle 80" (2m) wide at can do 1080i at OK brightness. Two 7" machines will do 1080p AND with more brightness AND at a desired viewing angle with a ~100" (2.5m) screen. Who knows if the convergence/geometry can be adjusted sufficiently or stable enough to make a go of a blend with 7" machines, but I'm hoping 2 ECPs will *begin* to approach one G90 when setup for 100" image. Should look a crap-ton better than one ECP.
BTW, folks need to be careful on assuming a blend simply enables one to go big and gaining brightness, too. Going from a 2m wide screen with one PJ to 3m screen with two PJs actually results only in a moderate brightness increase. That is, the area of the screen more than doubles in going from a 2.4:1AR @2m width to the same AR at 3m width. Meanwhile, the light output goes up maybe ~3X (2.4:1 portion of one 4:3 TO 90% of both PJs in 4:3 AR).
Sorry if these musing aren't fully informed, but I'm happy for my thoughts to get straightened out and kicked around by others...
cheers,
Matt
| Posted: Sun May 12, 2013 5:10 pm Post subject: |
Guys
Two ECPs are not a preferred starting point, but they are a start. A 1.0 gain screen fabric is required, so it is equally bright off-axis as it is on-axis.
With one projector firing 16:9 you are only employing 75% of your 16:12 available phosphor. With 2.35, you are down to 56%. So to be able to use all the available phosphor And two projectors, three times the light output of one projector is enjoyed.
incova
| Posted: Sun May 12, 2013 9:12 pm Post subject: ok |
So if I wanted two 9500 PJs and a screen that is 300cm wide what size room would that require in terms of depth?
Basically is a room thats 5 metres by 4 metres large enough in terms of depth for this?
the less I know.
| Posted: Sun May 12, 2013 9:41 pm Post subject: |
Okay
A 9500 with room to access the rear, lets say the projector is 48" front to back (122 cm) so if your 5 metres is the available room length, you have 378 cm from lenses to screen. This could work with ceiling mounted projectors. Presuming a 20% blend overlap, worst case a 1.0 throw ratio, your room would support a 378 cm screen width. If 4 metres is the long dimension, 278 cm screen width. Maybe a smidge more.
incova
| Posted: Sun May 12, 2013 9:57 pm Post subject: cool |
Thanks so much Tim.
the less I know.
| Posted: Mon May 13, 2013 12:53 am Post subject: Re: cool |
| incova wrote: | | Thanks so much Tim. |
Learn imperial measurements will ya? They come from over there!
incova
| Posted: Mon May 13, 2013 1:08 am Post subject: yup |
They do, I cant stand them lol, you should see what the british admiralty used to use................
the less I know.
