haireez
| Posted: Sun May 05, 2013 5:00 am Post subject: Vision 1 Synchronization Issue at 1080p 72hz |
Just recently, my vision 1 has issues to synchronize 1080p at 72hz. Its been doing well all along but now, it just won't sync anymore.
Any clue what went wrong? Any board that I should look at that might cause this?
By the way, it doesn't have issue if I force 120hz or 144hz using 3D Fury.
_________________ 2 White Vision 1
| Posted: Sun May 05, 2013 1:45 pm Post subject: |
Hello
Are you losing h sync, v sync, both? Push ** and see if the scan frequencies show up. It may be a problem in your source.
haireez
| Posted: Mon May 06, 2013 1:50 pm Post subject: |
Hi Tim,
You're absolutely right!
I'm not too sure why suddenly it doesn't work at 1080p 72hz before.
What I did was I updated 3D Fury to the latest firmware and force the high frame rate to 72hz and now it does work.
Thanks Tim!
