Can A Bulb Projector run on RGBHV?
larryp
Posted: Thu Apr 18, 2013 3:31 am    Post subject: Can A Bulb Projector run on RGBHV?
If i got a bulb projector, Can it be hooked up to RGBVH cables?
What would be needed?
Posted: Thu Apr 18, 2013 3:40 am    Post subject:
Yes, if it has a VGA input. Get a VGA to 5 BNC cable. BEware however, that a lot of digitals are limited to certain frequency ranges of the VGA input signal, they can't be fed a variable weird resolution like most CRT projectors can.
larryp
Posted: Thu Apr 18, 2013 3:52 am    Post subject:
I just use Direct tv, A blue ray dvd player & a video game console- Old 3DO unit.
My cables are already run in the attic/ceiling for my crt 1272 sony.. Pj would be ceiling mounted. Would like to keep the same setup.
Just gathering info IF the sony had to go
Posted: Thu Apr 18, 2013 3:55 am    Post subject:
You'll need to check the specs of the digital to see if it will support the resolution you want.
larryp
Posted: Thu Apr 18, 2013 5:08 am    Post subject:
My HD is 1080I on thec crt, and I'm not sure what res regular satelite is.
Posted: Thu Apr 18, 2013 2:21 pm    Post subject:
Go to www.projectorcentral.com and see if the projector you want to install will support the resolution(s) you want to run. Use their search engine to pull up the specs on the projector make and model.
