hal
| Posted: Sun Mar 17, 2013 8:06 pm Post subject: G90 and Lamagen Radiance XD output frequency |
I have been looking at the "sale" threads on the Radiance XD. From those that have the XD, or have worked with the XD my question are.. Are you limted to the output frequency? I have zero interest in 3D. Right now my output if with the PS3. Like most of us, we have a library of standard DVD's and are moving to Bluray. For scaling the output of my DVD player should I look at the older Radiance?
I have the Moome card and John's DVI cards installed right now.
Words of wisdom are welcome.
ElTopo
| Posted: Sun Mar 17, 2013 8:29 pm Post subject: |
Try 817p@72Hz for scope. Input card has to accept it of course .
ElTopo
hal
| Posted: Sun Mar 17, 2013 8:59 pm Post subject: |
ElTopo, I see that you have the newer XE.. Does the XD cap it at 72 or 60Hz..
ElTopo
| Posted: Sun Mar 17, 2013 9:01 pm Post subject: |
You have updated to the latest firmware?
There should be 817p in the resolution menu. XD should handle it also.
hal
| Posted: Sun Mar 17, 2013 9:40 pm Post subject: |
I do not have a Radiance XD yet.. My questions are for those that do. Can it scale standard DVD's to 1080P at a high enough frequency to have a good picture. I know that with the latest HTPC's one can get great results.
| Posted: Sun Mar 17, 2013 10:29 pm Post subject: |
| hal wrote: | | I do not have a Radiance XD yet.. My questions are for those that do. Can it scale standard DVD's to 1080P at a high enough frequency to have a good picture. I know that with the latest HTPC's one can get great results. |
Yes, but with the XD, you will not be able to do full blown 1080P at 72hz, you'll have to run 1080P@60hz.
817P@72hz works fine.
3D also works great.
stridsvognen Guest
| Posted: Sun Mar 17, 2013 10:38 pm Post subject: |
You can for sure always get 1080P 60hz out. The Radiance is for sure the best scaler you can get, and you will do just as well with a mini if your DVD player have HDMI out. There is better deinterlacers for SD signals than the Radiance, so you might prefer a progressive output from your player.
It can be a problem if your playing PAL DVD like 50 hz can be a bit annoying on a CRT.
kabuby77
| Posted: Mon Mar 18, 2013 12:40 pm Post subject: |
You can choose between:
1920 x 1080 @60
1920 x 817 @72
If you want 1920 x 1080 @72 you have to buy the XS/XE 3D+, but it is suitable only for top 9"
