barco_75
| Posted: Tue Mar 05, 2013 2:06 am Post subject: I'm going mad! |
I've been spending a good deal of my time tinkering with a Barco 808 graphic the past month which I acquired after my Barco 708 died. Unfortunately, the past owner removed all the guts to get it off the ceiling leading to glorious projector fun. Picture was flickering on the 808 and turns out the lead to the G2 wasn't connected. After getting that sorted out, I found the focus and horizontal deflection board had a screwed up connector frying that as well.
Now that I have that fixed, I am having issues syncing my Bluray through my HDFury version 1. I've used the same Bluray, HDMI connectors, and HDFury on the 708 so I know they work. I thought perhaps the length of the cable was an issue, so I tried it with an 18" HDMI cable that was part of the original setup and still problems. I'm hooked up on Port 5 with 5 BNC. 24 frames is set off, 1080i setting on the Bluray. I can get the Bluray home screen on the projector no problem, however, I do get a horizontal banding which distorts the image at the top. If the home screen is on too long, the Barco looses sync and goes black saying "no source found". When I play a movie on the Bluray, havoc ensues. The image goes blank ("no source found") then it might start up, image start to scroll, image goes blank, etc. I have no issue displaying S-video from VHS. I can't tell if the VHS has the Horizontal Banding issues since all my tapes are garbage due to age.
Should I try port 3? Would I have better luck? I've got to buy the DB15 to DB9 adapter to try that. What's going on with this. It's frustrating as hell.
barco_75
| Posted: Tue Mar 05, 2013 2:20 am Post subject: |
FYI, projector does not exhibit the horizontal banding issue when using the internal test patterns matching the frequency of the Bluray home screen. Not sure if it's relevant but I do still have an I2C error :FOH after replacing the focus and horizontal board. I had the same error prior. I just shifted the raster using the pots on the board.
| Posted: Tue Mar 05, 2013 6:51 am Post subject: |
How have you connected the BD player to port 5 since no BD player has vga or bnc out? If there is no device in the video chain to strip HDCP encoding then there will be no picture if you are outputting a HD image.
| Posted: Tue Mar 05, 2013 6:52 am Post subject: |
| barco_75 wrote: | | FYI, projector does not exhibit the horizontal banding issue when using the internal test patterns matching the frequency of the Bluray home screen. Not sure if it's relevant but I do still have an I2C error :FOH after replacing the focus and horizontal board. I had the same error prior. I just shifted the raster using the pots on the board. |
I2C could be caused by convergence tray.
| Posted: Tue Mar 05, 2013 6:55 am Post subject: Re: I'm going mad! |
| barco_75 wrote: |
Should I try port 3? Would I have better luck? I've got to buy the DB15 to DB9 adapter to try that. What's going on with this. It's frustrating as hell. |
VGA to port 3 requires a custom cable not an adapter. At least I am not aware of any off the shelf adapters for this purpose.
Ile
| Posted: Tue Mar 05, 2013 7:50 am Post subject: |
Port3 might help to possible positive sync issues caused by BR player, it have force syncs to negative switch.
What are you meaning by horizontal banding at top?
Horizontal banding is at left edge and is caused by too small porch settings from source (timings designed for digital display). Scaler can fix timings.
barco_75
| Posted: Tue Mar 05, 2013 2:17 pm Post subject: |
The hdfury takes care of the 5 bnc or VGA output and striping hdcp encoding. I wasn't aware a standard converter didn't work but I kind of expect it may not. I see the pin out on the site. Does anyone sell a cable made? I could make one if I had to but if anyone is already selling them it may be easier. I have an extron box which could switch output to negative but I do t have cables for it yet and was hoping I wouldn't need it. Is it possible for the bluray to output both positive and negative sync? I thought since the home screen image worked it must have been negative? The banding I'm describing is near the top of the image (but not at very top edge). The hole image is shifted over horizontally in one horizontal band ( or section). The band is not very tall. Does the convergence tray cause FOH error in particular? Per the service manual that chip is located on the focus and horizontal deflection board.
barco_75
| Posted: Tue Mar 05, 2013 2:43 pm Post subject: |
I've also heard that port 3 is more finicky than port 5 but port 3 has slightly better quality. Has anybody used the fury version 1 with success on the barco 808 graphics? If so how was it hooked up?
barclay66
| Posted: Tue Mar 05, 2013 5:10 pm Post subject: |
I had tried an HDFury I on my Barco Graphics 801s (input section almost identical to the 808). No success on either Port 3 or Port 5 due to sync issues. I then switched to an HDFury III, forced negative sync and everything was well. In Your case the Extron box could help. I'll take a look at the SM later regarding the I2C error...
Regards,
Barclay66
Hulio
| Posted: Tue Mar 05, 2013 6:24 pm Post subject: |
I used a HD Fury 1 on port 3 of my BG808 for several years without problems ( PS3 --->HDMI to DVI cable --->HD Fury 1 --->VGA to DB9 cable ---> port 3 on Barco ).
From the symptoms you describe, it seems you don't use the optional power supply for HD Fury.
Also, on non S Barco's, port 3 delivers a better PQ than port 5.
barco_75
| Posted: Wed Mar 06, 2013 2:35 am Post subject: |
I don't have the optional power. Hulio is your VGA to db9 a custom cable or did it come with your Fury? I'm curious what Barclay66 discovers about the i2c error. I'm going to need some adapters to try this out. Hopefully I can get this to work.
barclay66
| Posted: Wed Mar 06, 2013 7:57 am Post subject: |
| barco_75 wrote: | | I don't have the optional power. |
Then You should add this first.
| barco_75 wrote: | | Hulio is your VGA to db9 a custom cable or did it come with your Fury? |
The HDFury red edition had a Port 3 cable included (Blue Edition -> VGA, Green Edition -> 5xBNC).
| barco_75 wrote: | | I'm curious what Barclay66 discovers about the i2c error. |
Basically there must be something wrong around IC52 on the Focus/Magnetic shift board but You already know that from the service manual. Just some more background on this:
The I2C bus is fairly simple. It only requires two signal lines (clock&data) and allows for up to 128 devices workin on one single bus. Usually there's one controlling master device and all the others are slave devices. Each device is identified with its own 7-bit address and will listen to it.
In Barco projectors we will find lots of I2C devices of which the most common ones are the digital potentiometers (Barco "Bella" chips, SC76013). These are being used in order to control all kinds of usually analog settings (e.g. there are dozens of them on the convergence control board).
In Your case it is IC52 controlling the Blue/Red/Green picture shift controls and obviously IC52 isn't able to do so.
During the PJ's startup procedure the main controller will scan all known I2C addresses and listen for acknowledge messages from each device. By this the presence of several boards (especially the optional ones) and their functioning is determined. So, IC52 doesn't acknowledge at the moment and will not react to control commands either.
The reason could be IC52 itself or some part in the I2C bus circuitry near it. On the Focus/Magnetic shift board they're using some additional optocouplers in order to isolate IC52 electrically from the bus (seems to be necessary as IC52 isn't powered from the standard supply line). Almost any defect in this section could lead in loss of the bus connection (IC50, IC52, Q50-Q54).
Check for shorts or try a spare board...
Regards,
barclay66
Hulio
| Posted: Wed Mar 06, 2013 8:12 pm Post subject: |
Indeed, my HD Fury 1 came with VGA to DB9 cable.
| Posted: Thu Mar 07, 2013 4:15 am Post subject: |
| barco_75 wrote: | | The hdfury takes care of the 5 bnc or VGA output and striping hdcp encoding. I wasn't aware a standard converter didn't work but I kind of expect it may not. I see the pin out on the site. Does anyone sell a cable made? I could make one if I had to but if anyone is already selling them it may be easier. I have an extron box which could switch output to negative but I do t have cables for it yet and was hoping I wouldn't need it. Is it possible for the bluray to output both positive and negative sync? I thought since the home screen image worked it must have been negative? The banding I'm describing is near the top of the image (but not at very top edge). The hole image is shifted over horizontally in one horizontal band ( or section). The band is not very tall. Does the convergence tray cause FOH error in particular? Per the service manual that chip is located on the focus and horizontal deflection board. |
What resolutions have you tried and is the result the same at each??
barco_75
| Posted: Sat Mar 09, 2013 6:22 pm Post subject: |
Success! I figured out the sync issue!!!!!! The Extron Box solved the issue. I didn't have the right cables to hook up the Extron Box (nor could I find any at the local stores), but I did have four BNC to RCA cable adapters (=2 BNC cables). So I hooked up the composite sync and Green only from the Extron (feed by the HDFury) and I got a stable image with no banding. Tried the same on the Blue and Red hookup and all is good. I'm guessing the issue is with the Blue Ray not having a negative sync or maybe the Barco doesn't like the individual horizontal and vertical syncs (which I couldn't test since I didn't have the right cable). I still can't get the computer to sync but I'm guessing I need a power adapter for the Fury (even though I didn't need the adapter with my last setup).
Still get the FOH error which comes up with the two boards I have tested. Barclay, it sounds like the FOH error has to be limited to the Focus/Mag shift board (and not another board), correct?
Has anyone tested the difference from using port 3 vs port 5 on the non-S 808? Is it a dramatic difference? Is it worth upgrading to the Fury 3 or Moome Card for better picture quality? Is there a noticeable difference? I have some HD-145 lens which I'll have a friend fabricate an adapter so that should make a big difference. The HD-8 lens have poor outer focus based on my first alignment and setup.
barclay66
| Posted: Sat Mar 09, 2013 7:24 pm Post subject: |
| barco_75 wrote: | | Still get the FOH error which comes up with the two boards I have tested. Barclay, it sounds like the FOH error has to be limited to the Focus/Mag shift board (and not another board), correct? |
Yes, most probably. The address indicates the I2C device not responding...
Regards,
barclay66
| Posted: Sun Mar 10, 2013 1:28 am Post subject: |
The FOH can (from what I've seen) come from the focus/shift board. His replacement came from me, I'll send another one out. If it's still showing that error, we'll have to do some digging...
barclay66
| Posted: Sun Mar 10, 2013 11:42 am Post subject: |
IC52 is one of five I2C devices on the Focus/Shift board. There are only a few options why You could encounter the FOH error:
- IC52 is bad, doesn't respond and/or to execute I2C commands -> Replace Focus/Shift board
- IC52's power supply is bad (+SH/-SH: generated on board) -> Replace Focus/Shift board
- Focus/Shift board's power supply is bad (+SHIFT/-SHIFT: generated on SMPS) -> Replace SMPS
The I2C communication between the controller board and the Focus/Shift board should be OK as the other four I2C devices seem to respond...
Regards,
barclay66
Edited some typos...
barco_75
| Posted: Mon Mar 11, 2013 4:06 am Post subject: |
Thanks for the tips. I'm hoping the new board solves the issues.
