tromatus
| Posted: Mon Mar 04, 2013 11:47 am Post subject: htpc or not htpc? |
hi all,
any specialist from HTPC can tel
me if is a goog thing or not to use
with a barco 1209?
why i ask it?
because my blue tube is dead.
i think it is dead because the htpc
display whites pictures like windows folder.
i dont display white picture for a long time,just for one or two minits
only.
just enough time to choose my film....
if someone can explain this problem??
thanks guys
HK-Steve
| Posted: Mon Mar 04, 2013 1:57 pm Post subject: |
Many people use a HTPC as their primary source, so this is not your plroblem.
Have you tested the projector with another input other than the HTPC? or internal test patterns.? Is the blue tube still not working??
Is the Blue not working at all?
Error lights on the projector?
Cheers
Steve
HK-Steve
| Posted: Mon Mar 04, 2013 1:58 pm Post subject: |
Also,
Some projectors have a full white warmup screen, which can be for 20minutes, so don't worry about full white screen.
Cheers
| Posted: Mon Mar 04, 2013 5:53 pm Post subject: |
I also use HTPC, my background is plain black, I only have only a few icons on desktop, and move them regularly, the taskbar is auto-hiding the remaining line is blanked off by the pj, that's how I do.
tromatus
| Posted: Mon Mar 04, 2013 7:17 pm Post subject: |
| HK-Steve wrote: | Many people use a HTPC as their primary source, so this is not your plroblem.
Cheers
Steve |
yes i have tested the projector with
another input>>blue ray player.
i get same issue>>>the blue tube works fine
if the bakground colors are not too bright.
when the background color go white,
the picture scrolls from top to bottom 5 or 6 times and the barco go off.
i must restart it...
my blue tube are not very old.
it have around 2000H only...
if i plug another blue tube.
anything go fine.
I wonder if the fact to display a white image,like windows
folder not tire tubes?
HK-Steve
| Posted: Mon Mar 04, 2013 8:52 pm Post subject: |
OK, Still sounds like a projector problem.
Someone with Barco experience needs to chip in here. I know Marquee's, plus a little Sony.
2000hrs is no worry at all, unless they are driven hard, high contrast and brightness.
The scrolling of the image is the pointer though. Anyone???
Hmmm, just a thought, is the output from the HTPC too hot?? as in Higher voltage. 0.7v is the normal output.
Cheers
| Posted: Mon Mar 04, 2013 11:31 pm Post subject: |
Sounds like a bad cable from the HTPC. Which input are you using on the Barco?
| Posted: Tue Mar 05, 2013 6:47 am Post subject: |
Sounds like a frequency problem. What resolution and refresh rate are you using??
Ile
| Posted: Tue Mar 05, 2013 8:04 am Post subject: |
If your old blue tube works fine, new one is probably partly shorted. With long lasting full white image cathode shorts inside tube to heater, you should hear snap when that happens and then projectors shuts down.
Gently tab tubes neck to remove debris from gun assembly and then go to service menu and use crt run in cycles function 2-10 hour. It flashes full white image and should burn rest of that debris away. Make sure that flashing image is inside tubes face before leaving it flash by self.
Even better if you can find someone with sencore crt rejuvenator that have function to make this same "sh*t burning" process faster and more effectively. Also normal use will probably burn that debris, but it will take longer and it's pretty annoying to have few shut down during movie.
tromatus
| Posted: Tue Mar 05, 2013 11:26 am Post subject: |
| HK-Steve wrote: |
Cheers |
how can do to test it?
>>i use port 3 with hdfury 2.
>>resolution: 1280*720@60
but dont think that is the problem because
with another blue tube the barco works fine
HK-Steve
| Posted: Tue Mar 05, 2013 12:56 pm Post subject: |
With the hdfury you should be ok,
Definately a tube problem, do as Ile suggested.
