Radiance XE ok in enclosed cabinet?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products
ScottJ
Posted: Sun Mar 03, 2013 11:16 pm    Post subject: Radiance XE ok in enclosed cabinet?
I'm installing a new XE, and the best location for me is inside a cabinet that is open only on the front, with about 2" open space above the box. Is this okay, or should I be worried about heat issues?
Posted: Mon Mar 04, 2013 3:35 pm    Post subject:
I would email support@lumagen.com just to confirm.
With electronics, usually the cooler you run it, usually the longer it will last.
Posted: Mon Mar 04, 2013 4:26 pm    Post subject:
I think you will be fine. It would be better if you could get some ventilation from the rear though. Any chance you can drill some holes or open up behind the XE?
A MINI packed that tight could be a problem, but the XE and XS have much better cooling.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products All times are GMT
