Neon-line
| Posted: Tue Feb 26, 2013 9:16 am Post subject: Unknown projector, does somebody know it? |
Hello everybody.
I am hungarian, so my english is not the best. I am sorry!
I need help, maybe somebody could give me.
I have an old crt projector, and it is unknown.
Does anybody know it?
Here I attache photoes of it.
Thanks!
Neon-line from Hungary
| Description: |
| Filesize: |
367.01 KB |
| Viewed: |
5443 Time(s) |
| Description: |
| Filesize: |
418.15 KB |
| Viewed: |
5431 Time(s) |
| Description: |
| Filesize: |
344.88 KB |
| Viewed: |
5416 Time(s) |
| Description: |
| Filesize: |
337.32 KB |
| Viewed: |
5391 Time(s) |
| Description: |
| Filesize: |
373.05 KB |
| Viewed: |
5380 Time(s) |
| Description: |
| Filesize: |
380.07 KB |
| Viewed: |
5377 Time(s) |
| Description: |
| Filesize: |
388.14 KB |
| Viewed: |
5385 Time(s) |
barclay66
| Posted: Tue Feb 26, 2013 11:28 am Post subject: |
Some of the boards look like those from Grundig Television sets (the beige ones). Maybe the large one has some part number (e.g. 29504-xxx.xxx) that You can post. Some look like self-developed (dark green ones). In general it seems to be a television chassis which has been modified for three tubes plus analog convergence control.
I'm quite sure that this projector will only do television scan frequencies (H=15KHz/V=50Hz). No progressive scan and no HD possible, sorry...
Regards,
barclay66
Edit: Seems to be a Maxivideo VT 2000 (Italian product)!
| Posted: Tue Feb 26, 2013 11:41 am Post subject: |
Let me be the first to say wlcome to the forum (also from Hungary)!
It looks like a european made stuff (ITT?), probably from 80's.
While there is an RGB input so in theory you can attach a computer to it, but I think it will only support EGA/CGA, or 480i (SDTV). Not a high-end stuff that's for sure.
Neon-line
| Posted: Tue Feb 26, 2013 1:13 pm Post subject: |
Yes, You are right both.
This is an old one, maybe 30 years old, and probably made in Germany. There are german labels on the pcb.
I bought it, because I found it interesting.
I have an other same old, but much better, a Sony KP 7210 PS.
That is a beautiful piece! About 110 Kg!
| Posted: Wed Feb 27, 2013 12:52 am Post subject: |
An analog set with a huge number of trim pots. Any instructions?
Tube necks are really long for an ES set.
donaldk
| Posted: Sat Mar 30, 2013 4:15 am Post subject: |
Maxivideo is Italian. Not sure, but read that much later there was some sort of oem relationship with them doing an entry level video-only HT Barco CRT projector, wasn't there India production on that unit to lower cost?
https://www.curtpalme.com/forum_archived/viewtopic.php@t=19413.html
