ron paul
Joined: 25 Feb 2013 Posts: 9 Location: Auckland New Zealand
| Posted: Mon Feb 25, 2013 4:22 am Post subject: Barco 801data hdfury3 setup |
Hi i am new to the forum and was wondering if any one can point me in the right direction. I have a Barco data 801 and am running a DVD iscan duo and hooked up to an HDFURY3 set at default running into RGBHV which came with the Fury3 and have a blank picture, not even a green pic What comes up is Unavailable please check impute source Wold dearly love to get these extra add on toys to Barco Have video and svideo source BUT i want better to show off how old like me is better than the new
| Posted: Mon Feb 25, 2013 6:58 am Post subject: |
Hello and welcome to the forum. How are the dip switches set on the HDFury3? Do you have the power supply plugged in?
Are you selecting input 5 on the projector?
\ What resolution do you have the iScan set to?
What source are you using into the iScan and how is it connected?
ron paul
| Posted: Mon Feb 25, 2013 7:31 am Post subject: |
Thank you for your fast reply The dip switchs are set to default on the fury3 and the power supply up and running, blue fury3 light on. Have always selected imput 5 Source into the iscan, xbox into comp1, skybox into hdmi1 Been through the menu and cannot find the resolution setting. Imput on the dvdo is set to auto,output set to hdmi a/v1
ron paul
| Posted: Mon Feb 25, 2013 7:34 am Post subject: |
Thank you for your fast reply The dip switchs are set to default on the fury3 and the power supply up and running, blue fury3 light on. Have always selected imput 5 Source into the iscan, xbox into comp1, skybox into hdmi1 Been through the menu and cannot find the resolution setting. Imput on the dvdo is set to auto,output set to hdmi a/v1 Blue light is on the dvdo so it is getting signal
| Posted: Mon Feb 25, 2013 2:11 pm Post subject: |
Change the sync switch on the Fury3. I'll bet it will work then.
ron paul
| Posted: Thu Feb 28, 2013 1:06 am Post subject: |
Appoligise for not getting back earlier. Well here goes Fury3 #1 set to on from default setting tried #2on #3 off Tried 2&3 on, Tried #2 off & #3on and 2&3 off Blank blank blank So have gone out and got a new cable that i'm going to set my android and or xbox up to by passing the dvdo and hdmi cable thats in the ceiling. Set everything back to the start and try again Its a matter of elimination Bloody plug and play stuff lol. If all else fails then have a look at the video board??? Will let you no how i go Cheers for your imputes
| Posted: Thu Feb 28, 2013 1:09 am Post subject: |
Just FYI, ANYTHING to do with HDMI is rarely plug and play. How long is the HDMI cable going through the ceiling, and how old is it? If over 25' and over 3 years old, it easily could be the issue. Bypass it with a short (6') cable from your source on the floor directly under the projector to the Fury at the projector. Also make sure your H and V cables on the Fury are the right way around. If unsure, reverse them, and try everything else you did as to the Fury settings.
ron paul
| Posted: Thu Feb 28, 2013 1:23 am Post subject: |
10metres coupla yrs old just taken the tape off the ends to do this job. Have got a short cable and the setup for the fury is v/sync (black) and the h/sync the white cable rest as per Cheers again Was being facetious about the plug and play as well Cheers Will let you no
ron paul
| Posted: Sun Mar 03, 2013 8:18 am Post subject: |
All sorted Default switch #1 on 2&3 off That was on an old led projector. Now to transfer it to the 801 Cheers
| Posted: Sun Mar 03, 2013 10:49 am Post subject: |
Hi, you will need 1 on, 3 off and you may have to play with DIP switch 2 depending on your source.
Also make sure to reset the H SHIFT on the HDFury3. Push and hold the H shift switch either way for 15 seconds.
ron paul
| Posted: Sun Mar 03, 2013 11:03 am Post subject: |
That's tmoras job. Least now I no it all works. Will keep you posted. Small steps lol Thanks so much
ron paul
| Posted: Fri Apr 19, 2013 2:38 am Post subject: |
All done whoohoo Am now just a calibration away from perfection Thanks Troops
