Sony D50 Fans
HK-Steve
Posted: Tue Feb 19, 2013 12:08 pm    Post subject: Sony D50 Fans
Hi Everyone,
Started my Sony D50 this morning, got the dreaded bad bearing sound from what sound like the powersupply fan.
Tried to find some specs for the fan, but came up blank.
Does anyone have any specs??
Curt, do you have any new, or good fans?
UC Fan
F412R-12LA-06 is the fan model number.
Appreciate any info or help.
Cheers
Steve
Posted: Tue Feb 19, 2013 5:52 pm    Post subject:
I'll have to check, and to think I've thrown out probably 6 D50 chassis last year, and tossed the fans as well.
Can you check which one it is? I should have the power supply and the CPU fan, I most likely do not have the large ones at the back of the chassis.
BTW, I don't know that it's critical as to the specs, as the D50 really doesn't run too hot. I would guess that as long as there is some movement of air on the power supply, you'll be fine.
I did find that out with the heat sink tunnel of the 12XX series between the D and E boards. I had my test set fan go bad, and I didn't have one, so I left it off. Even though that tiny fan moves little air, it made a big difference in the operating temperature of those heat sinks...
Posted: Tue Feb 19, 2013 6:13 pm    Post subject:
Steve,
Post the dimensions of the fan. It may be that a fan from a G90 or G70 will work also. You should try and stick with the JapanServo fans if possible. Computer fans will not trip the safety mechanism in the projector when they fail. This could lead to the projector operating without any fan...
Posted: Wed Feb 20, 2013 4:10 am    Post subject:
Why wont they? If its a 3 wire fan it should.
HK-Steve
Posted: Wed Feb 20, 2013 7:48 am    Post subject:
Thanks Guy's,
The original are 2 wire only, so I suppose any fan will do.
It is the power supply fan.
Cheers
barclay66
Posted: Wed Feb 20, 2013 7:58 am    Post subject:
Posted: Wed Feb 20, 2013 8:15 am    Post subject:
The tags were hiding your problem - it was the URL-unfriendly characters (parentheses) in the URL that was breaking the URL in the forum parser. If you take the tags off, you can see where the URL breaks:
http://media.digikey.com/pdf/Data%20Sheets/Copal%20Electronics%20PDFs/f412r_en(1).pdf
Change the ( to a %28 and the ) to a %29, and it's fine.
With URL tag:
Fan spec sheet PDF
Without URL tag:
http://media.digikey.com/pdf/Data%20Sheets/Copal%20Electronics%20PDFs/f412r_en%281%29.pdf
http://www.degraeve.com/reference/urlencoding.php
HK-Steve
Posted: Wed Feb 20, 2013 9:37 am    Post subject:
Thanks for the PDF's, much appreciated.
Chers
barclay66
Posted: Wed Feb 20, 2013 11:37 am    Post subject:
With URL tag:
Fan spec sheet PDF
Without URL tag:
OK, but I wasn't aware that I'd need to be a HTML/Forum Parser/URL-encoding geek in order to post a link Wink
Regards,
Barclay66
Posted: Wed Feb 20, 2013 1:46 pm    Post subject:
HK-Steve wrote:
Thanks Guy's,
Cheers
Really, only a two wire fan!!! The D50 was a lower end model compared to its brothers but I am still surprised.
Posted: Thu Feb 21, 2013 5:49 am    Post subject:
Me too, even the 1001 uses 3 wire fans!!
HK-Steve
Posted: Thu Feb 21, 2013 1:03 pm    Post subject:
Agree, but some pics,
Cheers
HK-Steve
Posted: Thu Feb 21, 2013 1:04 pm    Post subject:
These photos were before I cleaned the projector, after buying it for 100 Swiss Francs.
Cheers
Motobias
Posted: Thu Feb 21, 2013 9:37 pm    Post subject:
what a nasty little sucker !
cut a bigger hole and put a proper fan... papst Very Happy
FIGHTING STUPIDITY SINCE 1983
Posted: Fri Feb 22, 2013 5:30 am    Post subject:
+1 on the Papst, if you can find one NOT made in china. Go a 120mm and itll be much quieter.
