Marquee and focus
noos@xp37+
Posted: Fri Feb 15, 2013 9:04 am    Post subject: Marquee and focus
I just fund this very helpful lines on AVS. This will def. help me to judge my next setup:
(If you don't see well resolved phosphor grain on your screen in the center with electronic focus turned to 0, then your optical focus is probably off. Electronic focus does have 5 interacting adjustments (flair,dynamic astigmation, focus, permanent magnet astigmation, and triangle adjustment), so it takes patience to get it right, but if a professional has touched your machine, electronic focus should be near perfect.)
A quick way to check your electronic focus is to put up a grid test pattern and select any color(color, then #(1=red, 2=green, 3=blue)) to check. If cranking the contrast makes the lines bleed out in a non-uniform way, flair is bad. If turning up or down the picture->focus from 50 makes both vertical and horizontal lines sharper, then focus is off(utility->service->rgb focus). If adjusting the focus makes horizontal sharper while making verticle blurry(or vice versa), then astigmation is off.
Posted: Fri Feb 15, 2013 1:43 pm    Post subject:
Hello
Mostly helpful; I have never seen "phosphor grain" on a Marquee, that would be very distracting. Those wishing to learn about Marquee Magnetics alignment can look here: http://www.etechvideo.com/techtip9.htm
Beware the shock hazard inherent with reaching along a running CRT.
noos@xp37+
Posted: Fri Feb 15, 2013 7:06 pm    Post subject:
Certainly Tim, you page is over the top! The text I found will only help me to identify the faults in my setup. While the page you linked will privide the solutuion. Thanks!
noos@xp37+
Posted: Fri Feb 15, 2013 7:11 pm    Post subject:
...and I have phosphor grain on green - very distracting. (HD10r5m wtih Pt22-19)
