rickyn
Joined: 11 Jun 2011 Posts: 7 Location: Birmingham, AL
| Posted: Sun Feb 10, 2013 10:30 pm Post subject: G90 orange code 59 |
I've owned a G90 for 8+ years. It's been a very dependable unit, despite its current issue. About a year ago, I noticed after turning it on a orange code 59 displayed. After turning off and on again, the code disappeared and the projector worked fine. As time progressed the problem has worsened, and now it usually takes 3 or 4 attempts to turn the projector on.
I found a list of code from the sony service manual, however 59 is not listed.
Any G90 gurus know what a error code 59 means and how I might fix it??
Thank you,
Rickyn
Phoenixed
| Posted: Mon Feb 11, 2013 12:02 am Post subject: |
Sure its not an 89?
Phoenixed
| Posted: Mon Feb 11, 2013 12:04 am Post subject: |
Also you are prolly gonna wanna get that Dallas chip changed soon by Curt if you havent had it done already.
rickyn
| Posted: Mon Feb 11, 2013 12:18 am Post subject: |
It is definitively code 59. I double checked... and on the power up cycle the display flashes 88 red then orange (or vice versa). I replaced the dallas chip a few years back. It's good, I'm pretty sure...
thanks for the reply.
Ricky
rickyn
| Posted: Mon Feb 11, 2013 1:46 am Post subject: |
Does the LED display flip according to the setup of the projector. In other words, could this be code 65 instead? My projector is a ceiling mounted unit.
| Posted: Mon Feb 11, 2013 2:23 am Post subject: |
Flip both sets of polarity switches back and forth several times and see if that fixes the issue.
rickyn
| Posted: Tue Feb 12, 2013 1:48 am Post subject: |
Craig,
You were right on target with the polarity switches. I did as you suggested switching the polarity switches back in forth. That didn't correct the problem, however it did lead me to the solution. I noticed the door cover is made of thin plastic and was slightly warped. By stretching the micro switch level for the door I think it solved my problem. A couple more power cycles will verify the fix. Right now, I'm enjoying my theater again. ;^)
Thank you very much!!
rickyn
For future readers: Orange Code 65: The cover of the polarity switches does not shut completely (Sony Manual)
| Posted: Tue Feb 12, 2013 2:01 pm Post subject: |
Yeah, no problem. The error is most usually caused be the door not being closed all the way and the safety switch not betting pushed in all the way. The error can also often be caused by one of the polarity switches loosing contact so that one tube does not have deflection. Either way, I figured that opening the door and flipping all the switches would sort you out
If that hadn't worked I would have next suggested bypassing the safety switch on the door.
