Barco Graphics 800... HDFury3 to RGBHV no picture
crt_jones
Posted: Wed Jan 30, 2013 12:34 am    Post subject: Barco Graphics 800... HDFury3 to RGBHV no picture
Hi everyone...
i connected the BG800: MacBook Pro Mini DisplayPort->HDMI HDFury3 (set to negative sync)->VGA to 5 BNC into the BG 800 (port5) but i can't get a picture. Sad
First i thougt my RGB input board was dead, but i got a second BG 800 an swapped the board... same problem...
I get a picture from my DVD player using the "Video Input"
I use SwitchresX to use custom resolutions, but i cant get it to work.
Somebody got an idea?
I noticed that both of my RGB Input boards (761748) have 5 little switches marked with : blue, red, green,H,V
What can i do with these switches?
thanks for your help in advance...
Jonathan
Posted: Wed Jan 30, 2013 12:58 am    Post subject:
THE best thing to try first is a plain HD box, cable or satellite. See if that works. Don't touch those switches, they are termination resistors, and the pix will look weird with them turned off.
Do you have the power supply for the Fury? Does it glow blue?
crt_jones
Posted: Wed Jan 30, 2013 1:04 am    Post subject:
yes... got the power supply.. and it glows blue...
i don't have any HD box here...
wich resolution schould i try? i'm not shue how to set up the custom resolution the right way.
Posted: Wed Jan 30, 2013 4:03 am    Post subject:
I guess the only other thing is, are the H and V cables connected to the right inputs? There's no real color code for those two. You could also try sending it a component signal via the Fury, and select input 3 or 4. You should get a green image when you feed a component signal into the RGB input.
Posted: Wed Jan 30, 2013 4:28 am    Post subject:
Is the display port cable an Apple product or an aftermarket like Dynex? I've heard the aftermarket cables refuse to work with the HDFurys.
crt_jones
Posted: Wed Jan 30, 2013 10:59 am    Post subject:
i get a picture feeding a componet signal to port 4...
i also swapped the H and V sync cables (port5) but i don't get a picture...
the displayport to HDMI cable is a aftermarket product.. but it seems to work... i get a picture on port 4...
what should i try next?
Posted: Wed Jan 30, 2013 2:15 pm    Post subject:
Port 4 is RGBs, port 5 is RGBHV. Why not leave it set as port 4 then?
crt_jones
Posted: Wed Jan 30, 2013 5:42 pm    Post subject:
port 4 is only working when i feed a component signal to it... little bit green for my taste Smile
how can i connect the rgb signal to port 4?? is it ok just to combine H and V sync with a T-adaptor?
crt_jones
Posted: Wed Jan 30, 2013 6:21 pm    Post subject:
ah... port 4 is sync on green... now i see.. how do i connect to this?
Posted: Thu Jan 31, 2013 2:49 am    Post subject:
Try doing that. It still seems like the FUry may be putting out positive sync. Your other option is to get an Extron 203 or 202xi box that will act as a sync inverter. It works on every signal I send to it, and I've had lots of Barcos on the bench that I feed many signals to. My 202 box is on 24/7, and I run everything through it. (my bench scaler puts out positive sync, so it would never work on the Barcos)
THis is what you want:
http://www.ebay.com/itm/Extron-RGB-202xi-MBC-RGB-Buffer-w-cables-/360182886730?pt=US_Projector_Parts_Accessories&hash=item53dc92b14a
This one is a bit overpriced, but it does appear to have the VGA to custom 9 pin Extron input cable. Without it, you need to make one up yourself, which is a pain.
Troll eBay if you can wait a bit, you should pay no more than $50 for a 202xi with the input cable.
Better yet, bid on this. THe 203 is newer than the 202, and has a standard VGA input instead of that stupid 9 pin custom Extron input:
http://www.ebay.com/itm/Extron-RGB-203-Rxi-with-ADSP-/370746518795?pt=LH_DefaultDomain_0&hash=item565236ed0b
crt_jones
Posted: Thu Jan 31, 2013 6:43 am    Post subject:
thx curt Thumbs Up
ok.. this would be the solution... but i wonder why RGBHV is not working at all...
could i be cable length or quality? i've got a 3m VGA to 5 BNC cable (a cheap one). Or should the cable be ok, since it is working with component on port 4?
The HD fury 3 should support cable length up to 40-50 feet according to specs.
barclay66
Posted: Thu Jan 31, 2013 7:28 am    Post subject:
I'd recheck the HDFury's dip switch settings first. The HDFury 3 can output sync with negative polarity perfectly (I've been using it like this when I still had my BG801s), it's just that the dip switch logic is somewhat awkward:
If I remember correctly, You have to select "force positive sync" and "sync inversion" to get the right signal...
Regards,
barclay66
crt_jones
Posted: Thu Jan 31, 2013 7:32 am    Post subject:
hi..
i got that already...
Dip2=OFF= sync inverted
Dip3=ON=forced sync positive
thank you for your help... im happy for any suggestions
barclay66
Posted: Thu Jan 31, 2013 8:19 am    Post subject:
Maybe the 800 model is a little bit too old and unreliable (due to its age) for Your purposes. I still have two working Barco Graphics 801s (both have good tubes without significant wear) sitting in my basement and collecting dust. If You're living not too far away You can have one of them for free as long as You come over and pick it up. If Your're interested You can answer via PM...
Regards,
barclay66
crt_jones
Posted: Thu Jan 31, 2013 8:26 am    Post subject:
Regards,
barclay66
you got PM Wink
crt_jones
Posted: Thu Jan 31, 2013 10:13 am    Post subject:
I just measured the VGA to 5BNC cable... one of the sync lines is not connected to the D-sub connector.
I think thats why it worked with sync to green but not via RGBHV... was a brand new cable... Neutral
now im on my way to get an new VGA to 5 BNC... hope it will work then...
barclay66
Posted: Thu Jan 31, 2013 10:21 am    Post subject:
Glad You found it anyway!
You know: "When you have eliminated the impossible, whatever remains, however improbable, must be the truth." (Sherlock Holmes)
Regards,
barclay66
crt_jones
Posted: Thu Jan 31, 2013 1:08 pm    Post subject:
it was really the cable... its working now on port 5... unbelievable... all the stress just because of a (brand new) defect cable...
thank you all for your help!!
