WTF happened to this circuit board
Posted: Sun Jan 27, 2013 9:38 pm    Post subject: WTF happened to this circuit board
This is the bottom side of a Niles 12 channel amp power supply. Every trace on the bottom looks like this and every trace on the top looks normal. I pulled the supply to check for bad solder joints or something. SOMETHING is what I found.
 Filesize:  130.23 KB
 Viewed:  1598 Time(s)
barclay66
Posted: Sun Jan 27, 2013 9:47 pm    Post subject:
I've seen PCBs like this before. No need to worry. Sometimes solder gets under the PCB coating during flow soldering and then it will look like this. Sometimes it's intentional. The solder adds to the trace's power rating...
Regards,
barclay66
Posted: Sun Jan 27, 2013 9:49 pm    Post subject:
Nothing serious. It's just because of bad quality solder-stop paint, or badly adjusted wave-solder equipment, or they did this intentionally to lower tha resistance of the traces. What you see is just the solder gone under the solder-stop paint, you can verify this by heating up one trace.
