Barco 1208 Brightness/Contrast Onscreen Display Missing
yeme
Posted: Thu Dec 27, 2012 3:52 am    Post subject: Barco 1208 Brightness/Contrast Onscreen Display Missing
The projector is an Eisemann modded DVI 1208. The brightness and contrast both work but I do not get an onscreen display while making adjustments. The display for the inputs, ( 3 and 93), also do not show but function. Finally, the setup menu works and displays normal. Any recommendations as to the repair?
Posted: Thu Dec 27, 2012 1:51 pm    Post subject:
Hit the 'text' button. That shuts down the onscreen text display.
Ile
Posted: Thu Dec 27, 2012 9:26 pm    Post subject:
I guess that might be caused by Gregs mods, because he remove original text insert diode circuit and use something different for that stage.
yeme
Posted: Thu Dec 27, 2012 10:54 pm    Post subject:
As simple as text on/text off! Menu back
Thanks Curt
....the DVI mod was installed when I purchased the projector and has been a nice addition for the past 5 years. I just bought Moome's Mux FHD so I can utilize more modern source equipment.
Thanks again,
John
yeme
Posted: Sun Dec 30, 2012 5:16 pm    Post subject:
Yesterday I discovered my remote for my WD TV Live Plus box set my Barco to "text off" again (not sure which key). I do briefly remember seeing the cross coding discussed on various WD forums.
John
