| Posted: Sat Dec 22, 2012 12:07 am Post subject: I have a new toy. Now I can see WTF I'm doing. |
This is a screen shot at about 300X. It goes to 500X
| Description: |
| Filesize: |
94.58 KB |
| Viewed: |
2973 Time(s) |
_________________ Chip
| Posted: Sat Dec 22, 2012 7:19 am Post subject: |
Hallelujah he can see. He can see!
Nice macro you got there
| Posted: Sat Dec 22, 2012 1:21 pm Post subject: |
Anyone care to take a stab at what we;re looking at here???
| Description: |
| Filesize: |
107.89 KB |
| Viewed: |
2891 Time(s) |
barclay66
| Posted: Sat Dec 22, 2012 1:27 pm Post subject: |
I'd say it is a Flex-PCB or a similar foil connector. You find these inside digital PJs where they connect the panel(s) to the main board...
Regards,
barclay66
| Posted: Sat Dec 22, 2012 1:38 pm Post subject: |
Yep and that's a bad one. It's off by half a pad. If you look close you can actually see the conductive particals in the anisotropic conductive film used to make the electrical connection and there are not many of them.
This is a good one
| Description: |
| Filesize: |
110.99 KB |
| Viewed: |
2881 Time(s) |
| Posted: Sun Dec 23, 2012 1:12 am Post subject: |
Had to work up the nerve to remove the ribbon. F it up and the project is trashed. It was stuck on much harder then I thought but I managed to remove it without ruining the ribbon or board (at least not by my doing). Just descovered that I am out of alcohol to clean it up so it's off to the store. Here's the side of the ribbon that was stuck to the board. It came off pretty clean.
| Description: |
| Filesize: |
89.61 KB |
| Viewed: |
2827 Time(s) |
| Posted: Sun Dec 23, 2012 1:40 am Post subject: |
awesome.
| Posted: Sun Dec 23, 2012 3:41 am Post subject: |
Well the SOB is re-attached. That is a royal pain in the backside. If this does not fix it then there's a crack in a trace in the ribbon cable. This is as close as I could get. It's a one shot deal. When it touches, it's done.
| Description: |
| Filesize: |
145.82 KB |
| Viewed: |
2793 Time(s) |
