| Is 3D worth it |
| YES |
40% |
[ 4 ] |
| no |
40% |
[ 4 ] |
| it's great, but costs too much/is too much work for the quality |
20% |
[ 2 ] |
| Total Votes : 10 |
freidich
Joined: 15 Oct 2012 Posts: 54 Location: Philadelphia, PA & Providence, RI
| Posted: Sun Dec 02, 2012 2:50 am Post subject: 3D via 2 projectors |
What would be needed to do 3D video using two projectors, specifically 2 NEC XG 1351LC's? Is 3D worth it/does it really look considering it's not designed to play 3D video?
| Posted: Sun Dec 02, 2012 3:31 am Post subject: |
I do it perfectly fine with a RUNCO DTV991 ( which in my case is an XG852 ).
freidich
| Posted: Sun Dec 02, 2012 3:56 am Post subject: |
How exactly do you do it?
| Posted: Sun Dec 02, 2012 10:15 am Post subject: |
Using PowerDVD on a computer and using nVIDIA shutter glasses. There is almost no flicker that i can see at 72Hz, and the nVIDIA glasses dont seem to make much difference to the brightness. ( its plenty bright enough )
I use the RGB-HV input for it, and run the res at 1280x720p 72Hz. I get slight ghosting at the bottom edge in 16:9 movies, 2.35:1 movies there is none. Wont matter what refresh i run cause the green decay rate is a touch slow, and 65Hz is the lowest itll kick in the shutter glasses.
If youre blending 2 XGs id expect youll get abit of a ghosting issue doing it the way i do, but if youre stacked you might be fine, although stacked you may as well go polarised.
| Posted: Sun Dec 02, 2012 10:52 am Post subject: |
| CasetheCorvetteman wrote: | Using PowerDVD on a computer and using nVIDIA shutter glasses. There is almost no flicker that i can see at 72Hz, and the nVIDIA glasses dont seem to make much difference to the brightness. ( its plenty bright enough )
If youre blending 2 XGs id expect youll get abit of a ghosting issue doing it the way i do, but if youre stacked you might be fine, although stacked you may as well go polarised. |
What type of 3D is it?
| Posted: Sun Dec 02, 2012 11:23 am Post subject: |
Side by side, i have one movie here in top and bottom but havent watched it yet so cant report on if the ghosting is an issue or not.
Motobias
Joined: 08 Jul 2008 Posts: 163 Location: Osnabrueck, Germany
| Posted: Sun Dec 02, 2012 12:53 pm Post subject: |
with 2 projectors, you can do passive 3d, no problem with ghosting if you have proper maintainance of polarization (circular polarization preferred)
you nee filters in front of the projectors, according 3d glasses and a non-depolarizing screen !
_________________ Most peope talk about HD without knowing the meaning and how to do it RIGHT !
FIGHTING STUPIDITY SINCE 1983
freidich
| Posted: Sun Dec 02, 2012 7:58 pm Post subject: |
Yeah I would like to do polarized 3D. What type of hardware do I need to send the video to both projectors? And for 3D blurays or PS3 games, how do I make sure that the proper polarization is going to each projector? And where can I get the items you mentioned, motobias?
Thanks gentleman.
Motobias
| Posted: Sun Dec 02, 2012 8:11 pm Post subject: |
you can use a computer to separate the streams, nvidia supports 3d playback with separate streams to 2 different projectors.
there are other switchboxes around, which will do the same job but i have no experience with these.
then you'll need polarizing filters and glasses
i tried with 2 dlp projectors and it worked out well, but i am still hunting for a proper screen !
http://www.facebook.com/media/set/?set=a.10150403825268502.446567.738343501&type=1&l=f1324298fa
freidich
| Posted: Sun Dec 02, 2012 8:56 pm Post subject: |
Awesome! I presume two VGA outputs would be best for this? As far as glasses go, are they the same as the RealdD 3D glasses they give out in movie theaters?
Motobias
| Posted: Sun Dec 02, 2012 10:11 pm Post subject: |
yeah, realD should be circular polarized, just like some passive 3d television glasses !
make sure you get proper filters to get the best channel separation possible.
my filters used to testing are linear and not very practical, but i might use the frame and get some circular filters soon.
anyone knows a good supplier for sheets of circular polarization filters ?
dvh99
dvh99
| Posted: Tue Dec 04, 2012 12:37 pm Post subject: |
i guess you mean a stack and not a blend?
i wonder what happens with the 3d image at the blend zone?
| Posted: Tue Dec 04, 2012 11:48 pm Post subject: |
Have to be, cant polarize with 2 projectors if you blend, youd need 4.
| Posted: Sat Dec 08, 2012 5:31 am Post subject: |
Why not do 8 for that extra brightness?
| Posted: Sat Dec 08, 2012 5:53 am Post subject: |
16 would be the go, 4 for each quadrant. On a 72 inch high gain screen so youre not over working the tubes....
| Posted: Sat Dec 08, 2012 5:55 am Post subject: |
| CasetheCorvetteman wrote: | | 16 would be the go, 4 for each quadrant. On a 72 inch high gain screen so youre not over working the tubes.... |
HAHAH! 16 on a 15 gain 72" screen. Let me get my Ray Bans
| Posted: Sat Dec 08, 2012 9:05 am Post subject: |
Yeah mate, contrast on zero, brightness on zero, tubes will last forever
| Posted: Sat Dec 08, 2012 10:07 am Post subject: |
But don't forget that you'd need a private powerplant
| Posted: Sat Dec 08, 2012 12:46 pm Post subject: |
Way ahead of ya Gabor, allready got one
