SPL800
| Posted: Sat Nov 17, 2012 2:07 am Post subject: Something smelling from my Barco 1209s |
Yesterday during watching a movie I started to smell something burning.
during that time the pj works fine and everything is ok.
Any suggestion what I should do? Or check?
| Posted: Sat Nov 17, 2012 3:22 am Post subject: |
Open the case for a start, see if you can confirm this is where the smell is coming from.
| Posted: Sat Nov 17, 2012 4:57 am Post subject: Re: Something smelling from my Barco 1209s |
| SPL800 wrote: | Yesterday during watching a movie I started to smell something burning.
Any suggestion what I should do? Or check? |
Were you thinking real hard or did you eat Mexican food before this happened?
jaredjaric
| Posted: Sat Nov 17, 2012 5:12 am Post subject: Re: Something smelling from my Barco 1209s |
My guess is the quadrupler,the quad casing might have little cracks(arcings).
SPL800
| Posted: Sat Nov 17, 2012 2:40 pm Post subject: |
hi
what is the quadrupler?
where is it in the pj?
| Posted: Sat Nov 17, 2012 2:54 pm Post subject: |
http://curtpalme.com/Barco1208_Layout3.shtm
I agree, it probably is. If so, I'd keep using the set until it fails completely. I had a quad here once that 'fixed' itself after a few hours of running.
You can also pull every module out to check for burnt connections, sometimes the H output board can have solder joints that burn up. If any solder joints look burnt, DO NOT keep running the set, as failure can damage the tubes.
elpha
| Posted: Sat Nov 17, 2012 3:33 pm Post subject: quad hs |
Hello, some time ago I bought a quad on this forum, once installed in the barco there was a burnt smell, the quad was already when I bought HS. Shortly after he died.
I bought another Curt, it works perfectly, thank you Curt
I do not say thank you to those who sell me another quad that is not cool among hobbyists.
Elpha
SPL800
| Posted: Sat Nov 17, 2012 5:43 pm Post subject: . |
Thank you all.
Today I was running my pj for about 3 hours with no problem at all.
Do you think that I should take out some parts and check for soldering?
if so. which parts?
