1080i@96 with Lumagen HDQ
Corleone88
Posted: Mon Nov 05, 2012 4:38 pm    Post subject: 1080i@96 with Lumagen HDQ
Hello,
I am looking for 1080i@96 timings (Lumagen HDQ).
I tried this, but it didn't work (my Barco 808 understood 48Hz instead of 96Hz)
VTOT = 1218
VRES = 1080
VSYN = 10
VFRN = 124
HTOT = 2640
HRES = 1920
HSYN = 208
HFRN = 152
VRATE = 47.89
These values were given by a software (I don't remember the name)
Thanks for your help
Rolls-Royce
Posted: Fri Nov 09, 2012 5:08 pm    Post subject:
That looks like it might be for 1080p/48. My Radiance Mini-3d shows its timing for 1080i/60 output as 1920 and 540 (not 1080) at 59.94 Hz.
....Royce....
Posted: Fri Nov 09, 2012 6:03 pm    Post subject:
If I recall, on the HDQ you need to go about this in a sort of wonky way.
First select your output as 1080i. Once that is done, the Lumagen knows to do interlaced. Than modify the 1080i resolution with the parameters you want.
Than again, I forget. The HDQ may only support 1080i and no other interlaced resolutions... but I am sure I did it in the past... memory fades.
