janzy
| Posted: Sun Oct 14, 2012 11:46 pm Post subject: 9PG Xtra work in a 135LC |
Will the green tube from a 9PG Xtra work in a XG 135LC?
| Posted: Mon Oct 15, 2012 3:59 am Post subject: |
What is the number on the XTRA green tube and the green in the 135 you have? Youll need to remove it from the AC housing to mount in the LC.
| Posted: Mon Oct 15, 2012 7:16 am Post subject: |
They will work, the mechanical procedure is as Case said, and you'll need to do a very minor modification on the XG's neck board, two pins need to be tied together, but that's all
| Posted: Mon Oct 15, 2012 8:20 am Post subject: |
Wont that depend on the last 2 digits of the two tubes?
| Posted: Mon Oct 15, 2012 8:27 am Post subject: |
Well yes, but it's not that hard work to do the mod, and you'll be safe then.
| Posted: Mon Oct 15, 2012 11:30 am Post subject: |
But if the tube is the same number why do the mod?
