digitalayon
| Posted: Fri Sep 21, 2012 2:32 am Post subject: is there a 16:9 setting on a 9500lc |
Just blanked everything out. Using moome card and blue ray play. Getting only 4:3 and sides are cut off. Cannot remember how I did it a few months ago.
| Posted: Fri Sep 21, 2012 2:57 am Post subject: |
Sounds like the player is set up wrong. Not sure what you meant by saying I just blanked everything out ?
digitalayon
| Posted: Fri Sep 21, 2012 3:41 am Post subject: |
Player is set for 16:9....and I went back to factory mode.
Phoenixed
| Posted: Fri Sep 21, 2012 4:03 am Post subject: |
Something can't be right because the projector should just lock onto any resolution within reason. I am not trying to be a douche but are you sure its not 4:3 material?
Phoenixed
| Posted: Fri Sep 21, 2012 4:28 am Post subject: |
Make sure to set your retrace to short as well if you did factory reset your Marquee.
digitalayon
| Posted: Sat Sep 22, 2012 6:55 pm Post subject: |
Good call guys......It was the retrace.
Dertah
| Posted: Sat Sep 22, 2012 11:27 pm Post subject: |
I'm glad I read this. I have to setup my marquee 9500LC (really a Vidikron One) from a reset as well (changed the internal battery). Are there any other secrets like this that must be done when starting over from a reset?
Also, this may be a dumb question but I have read a lot on the site about adjusting the raster to use the most tube face. On the the Marquee is that just H and V size or is there some other raster setting hidden somewhere?
| Posted: Sun Sep 23, 2012 12:29 am Post subject: |
| Dertah wrote: | I'm glad I read this. I have to setup my marquee 9500LC (really a Vidikron One) from a reset as well (changed the internal battery). Are there any other secrets like this that must be done when starting over from a reset?
Also, this may be a dumb question but I have read a lot on the site about adjusting the raster to use the most tube face. On the the Marquee is that just H and V size or is there some other raster setting hidden somewhere? |
You could backup your config before you change the battery and then just wright it back after the swap.
| Posted: Sun Sep 23, 2012 12:31 am Post subject: |
Info...
https://www.curtpalme.com/forum_archived/viewtopic.php@t=26289.html
Phoenixed
| Posted: Sun Sep 23, 2012 12:56 am Post subject: |
+1 for Craig's advice.
The marquee loader program is an absolute must if you pay for a calibration. OR don't wanna spend days tweaking it back.
