Bro-ken
Joined: 04 Sep 2012 Posts: 10 Location: Cape Town, South Africa
| Posted: Fri Sep 14, 2012 12:19 pm Post subject: RE: the Barco 1208s - where is the flipout keypad? |
I've been abandoned at my post!? - I was advised by Curt to press Standby on the flipout keyboard - on the Barco 1208s -:
Flip out keypad? - I've not found it - Also I have no remote - when I got the Barco I was told they did not have the remote. (lost or sold?)
_________________ try not to project onto others.
scotha
Joined: 27 Mar 2006 Posts: 167 Location: Lilburn, Ga.
| Posted: Fri Sep 14, 2012 8:35 pm Post subject: |
The keypad is on the back of the machine. The door that hides the keypad is about 1" tall and about 8" long press it in and it will spring out.
_________________ pj. BD808s, BD801s
| Posted: Fri Sep 14, 2012 9:28 pm Post subject: |
Directly over the input connector area.
Bro-ken
| Posted: Sat Sep 15, 2012 9:09 am Post subject: |
Thanks - I thought there was something there! - I pressed Stby on the flip-out - it took a few seconds with lights flashing - to settle with the:
Stby Power - steady red
Main Power - steady red
Processor Cycles - flashing red
Operation (on the back panel) - Green
The Barco is humming - warming up?
- can it be operational? (with Processor Cycles flashing?)
No smells (no burning).
But no light from lenses?!
Is there procedure I'm missing?
Where to from here? - I'll check the manual.
scotha
| Posted: Sat Sep 15, 2012 1:44 pm Post subject: |
Have you tried hooking a video source to it? I'm running a 1208 also and love it.
| Posted: Sat Sep 15, 2012 1:55 pm Post subject: |
Press the 'stby' button on the keypad to turn the set on.
Bro-ken
| Posted: Sat Sep 15, 2012 3:23 pm Post subject: |
I have pressed the STDBY key - the results were as above - and below:
Operation shows - green (back panel)
on the control panel under folding cover:
Stdby -steady red
Barco humming(warming up) - though no light from projector at all.
Is there something must be done - to set up for projection-light?
| Posted: Sat Sep 15, 2012 5:05 pm Post subject: |
What happens when you press the TEXT button or ADJ button ? You use the ADJ button to get into the internal setup menu.
If you don't see a grid pattern after hitting the ADJ button try turning up the brightness control.
Bro-ken
| Posted: Tue Sep 18, 2012 10:09 am Post subject: |
Thanks for responses - I've not got any projection light - I've switched on again and in addition to the previous lights showing:
Stdby -steady red
Processor Cycles - flashing red (flickering)
and Back panel - steady green
there is now another light on (under folding cover):
Block Match - steadily(red)
I pressed the ADJ and Text - no detectable reaction?
One of the lights on a circuit card which was red is now green - and another that was red is now not lit.
After 10 minutes - no change - and I switched off.
| Posted: Tue Sep 18, 2012 1:01 pm Post subject: |
OK, so far so good. You may be missing the HV, which is indicated by a shutdown of the EHT board. There's a red LED on the top of the EHT board, which you can see by looking through the back of the set at the EHT board:
http://curtpalme.com/Barco1208_Layout2.shtm
http://curtpalme.com/Barco808_Layout8.shtm
If the red EHT light is on, that means the set is in HV shutdown mode to protect the set. THe HV quadrupler, EHT board itself or HV splitter will be causing that.
Also, on the row of green LEDs on the one board to the side of the set, there's a red light on it. Is that red light on?
Bro-ken
| Posted: Tue Sep 18, 2012 7:38 pm Post subject: |
There was a red light the second last time I switched on - next to a row of green - The last switch-on - only green. Also another red on a more central board was on - and the last time not.
EHT - I still have to find where that is.
Thanks - I'll check it soon.
| Posted: Tue Sep 18, 2012 7:42 pm Post subject: |
It's shown in the link above. Bottom right corner.
