olakjen
| Posted: Thu Aug 30, 2012 4:04 pm Post subject: Sony G90 VS JVC DLA RS65 |
hello a am locking to get the best picture quality in 2D movies , hwat do you people recomend
SONY G90 ore JVC DLA RS65
a have lumagen xe to colour corect
my room is a bat cave whidt 99% light controll
my screen is 100-106 wide
sorry for bad english
digitalayon
| Posted: Thu Sep 06, 2012 2:43 pm Post subject: |
well to be honest, most people here are diehards for CRT so you will get an obvious biased opinion. However that being said....the JVC projector you are choosing is not LCOS from the looks of it. So I would say G90. If it was the LCOS, then I would have to look at the condition adn the amount of hours on the G90 and compare from there.
kal Forum Administrator
stridsvognen Guest
| Posted: Fri Sep 07, 2012 1:21 pm Post subject: |
I'm sure you will get the best PQ, if you are willing to spend the time and money needed to get a G90 fitted with moome and lumagen you have already.
But if you worry about things like noise, heat, space and so on you need to go with the JVC.
You say your screen is 100" wide. what is that in diagonal? and is it a 16-9 screen or.?
I think the screen is maybe just a little big for a single G90.. i'm sure someone here knows.
| Posted: Fri Sep 07, 2012 1:30 pm Post subject: |
| Quote: | You say your screen is 100" wide. what is that in diagonal? and is it a 16-9 screen or.?
I think the screen is maybe just a little big for a single G90.. i'm sure someone here knows. |
It really depends on personal taaste, my friend was statisfied with his 100+" wide (painted wall) screen with a single 9PG xtra, and it was left at default settings, now he uses a Marquee 9000 and it also light up without sweat.
stridsvognen Guest
| Posted: Fri Sep 07, 2012 1:39 pm Post subject: |
| gjaky wrote: | | Quote: | You say your screen is 100" wide. what is that in diagonal? and is it a 16-9 screen or.?
It really depends on personal taste, my friend was satisfied with his 100+" wide (painted wall) screen with a single 9PG extra, and it was left at default settings, now he uses a Marquee 9000 and it also light up without sweat. |
Sure its all about taste, but if you want around 10-12 fl or more you might be disappointed. Also depending if your using a screen with gain or not..
I'm using a 94" wide screen =2,4m or 110" diagonal gain 1.0 and its about max to my 9500LC calibrated to 10fl
