janzy
| Posted: Wed Aug 22, 2012 11:47 pm Post subject: Xl135 vs xl135lc question |
Will the boards from a 135 work in a 135lc?
I was thinking of buying the plain 135 for a parts machine if parts work in the LC version.
| Posted: Thu Aug 23, 2012 12:06 am Post subject: |
common sense tells me YES but I could be wrong.
| Posted: Thu Aug 23, 2012 2:23 pm Post subject: |
I also believe they are the same, only the lenses and tube housings are different as far as im aware.
| Posted: Thu Aug 23, 2012 2:33 pm Post subject: |
NO, WRONG!
Neck boards, system boards and most other boards are different. Different voltage supplies for the focus boards and convergence boards. Same tubes but different housing. Different power supply. Buying a non LC for spare parts for an LC and vice versa is a waste of money.
The exception is the XG85, a non LC set. That uses the same parts as the LC sets, go figure.
janzy
| Posted: Thu Aug 23, 2012 4:15 pm Post subject: |
Thank you for that clarification Curt.
MikeEby
| Posted: Thu Aug 23, 2012 11:16 pm Post subject: |
Isn't there also some board differences between 1351 & 1352?
| Posted: Fri Aug 24, 2012 7:40 am Post subject: |
| Curt Palme wrote: | | NO, WRONG! |
Lucky you came along when you did Curt
