NEC Intelligent Switcher ISS 6010 question
janzy
Posted: Wed Aug 15, 2012 6:11 pm    Post subject: NEC Intelligent Switcher ISS 6010 question
I can grab one of these for $25.
Its populated with 5 video card modules, 3 rgb input modules and 1 rgb output card.
Is it worth having?
Tinman
Posted: Thu Aug 16, 2012 2:28 am    Post subject:
YES! These are very good. AND you could get a Moome board for it. Mine had one, not sure however if he still makes them.
Marc
This space for rent.
mc86
Posted: Thu Aug 16, 2012 3:48 am    Post subject:
Neat...I figured those were just some sort of crappy accessory. I noticed the control cable looked like a VGA cable and NOT a standard RS232 serial port. What gives with the special/custom cable?
Also, when it switches inputs, does it also send commands to auto-switch memory settings, etc. OR do NEC PJ's have some sort of internal auto-source recognition (ASR) like the Ehomes?
Matt
Tinman
Posted: Fri Aug 17, 2012 1:43 am    Post subject:
Matt
The control cable plugs into the projector to make it an integrated setup. But it can also run totally stand alone. These were expensive and very capable switchers. You can even plug a second output card into it for display on a second projector, etc.
I forget if it could take up to 4 or not.
Marc
