armstrr
| Posted: Mon Jun 18, 2012 12:31 pm Post subject: Stick with 9500lc or... |
Ok, so I have been away for a while, but recently popped in to check "the state of things" in CRT land
I started out with an 8500 from dragon 8 or 9 years ago. Sold the house and pj to a friend who still uses it
Current setup is a 9500lc. I got it around 4 years ago. It
Has some version of Parker mod, has color
C elements and i believe a first gen moome hdmi card A friend and I changed the glycol and replaced the bellows. It has hung faithfully for 4 years, with one hiccup involving the hvps. Replaced it and no real problems since
Recently the lumagen hdp's hdmi inputs
Quit working, so I have it hobbled up to use component inputs, but if I
Stay with the 9500 the lumagen will likely need to replace
The projector itself has started to need to be
Touched up a bit. The convergence is off noticeably until the pj is well warmed up. This may have something to do with using
The component inputs... Not sure. Maybe with the scaler
Replaced All will be well. Or perhaps sending the boards to dragan to replaces
Some aging parts will help. I do see some slight banding that scrolls vertically down the screen every minute or so... Again, this is likely aging components, right?
Note: we use the theater room virtually everyday... 1-1.5 hours
So I'm at a bit if a crossroad. Do I sink $500 into pj, and 2-400 into another lumagen hdp and then spend
The time to set it up again? Or do I make a clean break as I have read many of the "old guard" are (or have) and go to the "grey side"?
3d is not a deal breaker for me, but if i am spending some money anywy, perhaps opting for the radiance over an hdp is worthwhile since I can use it with either way I go ? I'm confused as
To whether any or all of the lumagen radiance vp can do
3d on a CRT... Or if it can, does the 9500 do it well? (there is a + model?) xd,xe,xs? I don't
See many posts with people doing 3d with crts. And then an additional accessory box is required, correct?
So at 8-900$, I am 1/2-1/3 the price of a half decent digital... Can anyone clear up some of my confusion so I can make an informed decision? I guess I would like to be talked down off the ledge, but I do need to be smart about this as with many... There is less time in the day to tinker than there used to be.
Thx!
Electeohome marquee 9500lc, lumagen hdp, 9' da lite higIh power screen denon 2809ci paradigm speakers home made dual stacked subs
_________________ Electeohome marquee 9500lc, lumagen hdp, 9' da lite high power screen denon 2809ci paradigm speakers home made dual stacked subs
armstrr
| Posted: Mon Jun 18, 2012 12:32 pm Post subject: |
Double post! Damn iPhone! Sorry.
| Posted: Mon Jun 18, 2012 12:39 pm Post subject: |
Keep the 9500LC for a a few more years.
After switching to the component input you would have to redo convergence and make sure the memory was unlocked for it before you do it so then it would be saved. The lock the memory again to preserve the changes.
Changing the CVA( convergence board caps and switching the resistors to a larger physical size will help keep the convergence stabilized quicker from cold to hot.
Also look for a used radiance if possible. it will come in handy later when you go Digital anyhow so it will not be money wasted.
I do not think digital at the price range you want are ready yet.
Unless you want to get a 65k Sim2 Theatro 80
stridsvognen Guest
| Posted: Mon Jun 18, 2012 2:14 pm Post subject: |
Athanasios is right i think.
I just got a 9500LC coming from a 7000-8000$ JVC, and i'm blown of my feet with this, even i'm not yet finished changing dirty glycol and putting my red C element.
ill say depending on how picky you are, can you live with some digital out of the box with no calibration, and trow in a new lamp when its used up, its plug and play, but if you desire realism black and true colors, and you know how to calibrate and set up your CRT, i think its quite far out in the future before you find any digital machine that will please you.
My own father is the most happy man with his new samsung 42" led tv who must be around 10000-12000K and artifacts frying around the screen all the time.
Ill never be pleased with anything less than the best i can get. And i push it and test it to the limit. Its all about how you prioritize your time and if you like playing with it.
Projectors and hifi is my hobby, i love it so its easy for me to say, and i fully understand why many will just settle with a small easy digital projector.
I'm just waiting for more cheep 9500 projectors on the marked, so i can stack them up for future parts.. So please sell it..
HaydnG90
| Posted: Mon Jun 18, 2012 2:18 pm Post subject: |
| Nashou66 wrote: |
Athanasios |
A CR of 1:7,000? Sounds like a real winner........
1st pj I've seen designed with 2 bulbs.... so double the running expenses.
| Posted: Mon Jun 18, 2012 2:27 pm Post subject: |
| HaydnG90 wrote: | | Nashou66 wrote: |
Athanasios |
1st pj I've seen designed with 2 bulbs.... so double the running expenses. |
Not necessarily; some two-lamp systems allow you to select running one lamp or two; if one craps in the middle of your gathering you still have a picture.
| Posted: Mon Jun 18, 2012 2:30 pm Post subject: |
All of the Radiance processors can support 3D. If you buy a new Radiance processor it will come with 3D at no additional charge. If you buy a used Radiance without 3D you can order a 3D upgrade for it (call or email me). The 3D upgrade is $499.
All of the Radiance processors need an optional 3D output that connects to a 3D transmitter. The XD, XS, and XE all use an HDMI dongle that goes inline with either of the HDMI outputs. The HDMI dongle MSRP is $399. The Mini can be ordered with a 3D output on board. The on board 3D for the Mini is $199.
I would keep the Marquee if I were you.
armstrr
| Posted: Mon Jun 18, 2012 2:39 pm Post subject: |
| CIR Engineering wrote: | All of the Radiance processors can support 3D. If you buy a new Radiance processor it will come with 3D at no additional charge. If you buy a used Radiance without 3D you can order a 3D upgrade for it (call or email me). The 3D upgrade is $499.
craigr |
So are the "plus +" models of radiance more desirable for CRT? Or do they all have the same capabilities with more recent firmware...
| Posted: Mon Jun 18, 2012 2:49 pm Post subject: |
| armstrr wrote: |
So are the "plus +" models of radiance more desirable for CRT? Or do they all have the same capabilities with more recent firmware... |
The PLUS option is designed specifically for CRT. The PLUS option allows the Radiance to run at much higher clock rates. This allows for support of 1080p 72Hz and for very high clock rates when running 3D. 3D requires a tremendous amount of vertical blanking so you can really utilize the high clock rates of the PLUS with 3D.
The XD does not support the PLUS option.
The XS and XE support the PLUS option. You can order it with a new processor for an additional $499 or you can upgrade it later also for $499 (say if you bought one used without PLUS). To add the PLUS option later you would have to send the unit to me or Lumagen for the upgrade.
You can run 3D without the PLUS option, but with the PLUS you can support higher 3D resolutions.
| Posted: Mon Jun 18, 2012 4:18 pm Post subject: |
I guess this is really going to depend on your budget. Is 3D that important? If it is, then to stick with CRT looks like it is going to cost you at least $1500 or more. I would say go digital in that case.
If 3D isn't that important, then I would say stick with CRT. If the tubes are good and you dont want to DIY, then send the boards to Drags. Maybe you can get the Lumagen repaired. If not, then you are still at a good price.
Most digitals today look pretty good, but the cheap digitals still are lacking. To me, the JVCs are the best, least expensive digital that you can buy now. You are still going to be set back $2k though.
| Posted: Tue Jun 19, 2012 7:01 pm Post subject: Re: Stick with 9500lc or... |
I'm going to obviously have a very biased opinion, even though I don't run 3D I love CRT and watch a movie every weekend. I have to admit though, dropping $3K on a new Moome card + all the Lumagen stuff for 3D is a tough pill to swallow.
I will say that you should not expect this though with any new digital. AAMOF, they have notoriously poor life-spans in situations where they are used every day as a TV.
| armstrr wrote: | I started out with an 8500 from dragon 8 or 9 years ago. Sold the house and pj to a friend who still uses it
digitalayon
| Posted: Mon Jul 02, 2012 8:59 pm Post subject: |
This was my point last year...I did a rant that aftermarket stuff for CRT is outrageously overpriced and often times more than the cost of the CRT itself. Now there are some exceptions. But some are not worth it. Even Curt said he was offended. But the expense of adding some devices are not what I have in mind when I think of the age of the technology. We need to do things to encourage CRT. Otherwise you get people that come here and see old school CRT?...BUY WHAT?!?! ADD THIS....ADD THAT.....f*ck THAT!!! Curt has done a fine job. But his stuff was written when 2007?! We didn't even have iphones or ipads then. I see a lot of breaking apart. And from what I have seen, its the haves and the havenot's that are really separating. If you have a Good CRT in good condition, most guys are keeping those. Re-tubing? I don't know! But if you do not have a higher end unit or that it does not do 1080p and it is getting old, the user is most likely going digital. I could be wrong on a lot of this....just my opinion.
tanwn
| Posted: Tue Jul 03, 2012 4:11 am Post subject: |
| digitalayon wrote: | This was my point last year...I did a rant that aftermarket stuff for CRT is outrageously overpriced and often times more than the cost of the CRT itself. Now there are some exceptions. But some are not worth it. Even Curt said he was offended. But the expense of adding some devices are not what I have in mind when I think of the age of the technology. We need to do things to encourage CRT. Otherwise you get people that come here and see old school CRT?...BUY WHAT?!?! ADD THIS....ADD THAT.....f*ck THAT!!! Curt has done a fine job. But his stuff was written when 2007?! We didn't even have iphones or ipads then. I see a lot of breaking apart. And from what I have seen, its the haves and the havenot's that are really separating. If you have a Good CRT in good condition, most guys are keeping those. Re-tubing? I don't know! But if you do not have a higher end unit or that it does not do 1080p and it is getting old, the user is most likely going digital. I could be wrong on a lot of this....just my opinion.  |
I can't agree with you more, it is always good to have more than enough spares, especially HVPS, quad, smps etc. If you own a 9" unit, the parts are indeed getting extremely rare and cost of a new one is exorbitantly expensive if not out of production. Alternatively you need to get it from the used market. A seller may not sell it cheap and you need to understand but i would say 1/2 to 3/4 price of a new one is reasonable but low ballers looking out for cheap deals may not be so lucky.
| Posted: Tue Jul 03, 2012 4:03 pm Post subject: |
| tanwn wrote: | | I can't agree with you more, it is always good to have more than enough spares, especially HVPS, quad, smps etc. If you own a 9" unit, the parts are indeed getting extremely rare . | the thread was specifically about a marquee 9500 and there is absolutely nothing rare about anything in that machine. MArquee parts are the same between all models and they are everywhere.
Only thing I can think of as rare is a Red C-element, and the 9500 didn't come with that part from the factory.
digitalayon
| Posted: Tue Jul 03, 2012 8:10 pm Post subject: |
"Only thing I can think of as rare is a Red C-element, and the 9500 didn't come with that part from the factory."
let me know when you have one!!!!!
mc86
| Posted: Tue Jul 03, 2012 9:58 pm Post subject: |
I kinda' get the impression you (the OP) want to go digital but are simply hesitant...Perhaps now is the right time to go see some digitals in action, price them, and decide based on what folks on here think. Maybe you'd decide the price-performance curve justifies the time, money, effort on the CRT...maybe not. Hard for us to know your personal desires and the tradeoffs you might make.
| digitalayon wrote: | | We need to do things to encourage CRT. Otherwise you get people that come here and see old school CRT?...BUY WHAT?!?! ADD THIS....ADD THAT.....f*ck THAT!!! |
The only way to encourage folks is to help them determine what components to get to fit their needs AND/OR perhaps to offer opinions as to what the "best" route for that person would be. It seems only natural that the solutions to adapt CRTs to current practices (3D, etc) would be expensive. Of course some folks will not want the have to think about it...I don't see a problem as that is fine for them.
I think this site may be slowly transitioning from a CRT "user" forum into a current-and-former-CRT "enthusiasts" forum. To me, it is encouraging there is a range of low-end hobbyest/users (like me), active, upgrading enthusiasts like Jeff, and already-gone-digital folks like Marc or Kal. This is a community not simply built upon a one, singular common interest or on users possessing machines of certain capabilities. That is a strength in helping folks get a lot of informed perspectives...
1080i looks good enough *for me* right now -- am I a "have-not"? I dunno, but I have passion to learn, share, and enjoy -- and those are important "haves" to have even if folks sorta' shrug at my low-end machine a bit. I managed to scrape together stuff for a few hundred bucks of a 2+ years -- it can be done. And for folks coming from a small LCD, etc, my ECP is a whole world of different!
Just some thoughts!
Matt
HaydnG90
| Posted: Tue Jul 03, 2012 10:13 pm Post subject: |
| digitalayon wrote: | "Only thing I can think of as rare is a Red C-element, and the 9500 didn't come with that part from the factory."
let me know when you have one!!!!! |
Isn't that the same as the one on the G90? I have one I'm selling in the Buy & Sell section.
| Posted: Wed Jul 04, 2012 5:15 pm Post subject: |
| HaydnG90 wrote: | | Isn't that the same as the one on the G90? I have one I'm selling in the Buy & Sell section. | yes, and unlike the green the Red in the G90 is actually SMPTE correct
jeffslife
| Posted: Wed Jul 04, 2012 11:41 pm Post subject: |
OK so what about the Blue C element on the G90 ?
mc86
| Posted: Thu Jul 05, 2012 8:40 am Post subject: |
As there is an exception to every rule, I'm sure to be corrected, but I do not think any CRT color-filtered the blue tube. The blue phosphors apparently have a good-enough emission spectra as-is.
Note: I do recall reading (all about lenses?) that early lenses were color-corrected for each color tube in a unique way...so while the lenses all looked clear to the eye, they had to be matched nonetheless. Later, the multi-layer technology came and made the lenses swappable between colors. Point being, don't confuse that early individual color-correcting with color-filtering (tinting) any of the lens, C-element, or coupling fluid (on AC machines).
Matt
