Dwin HD700 Problem
hhh222
Posted: Sun May 27, 2012 3:32 pm    Post subject: Dwin HD700 Problem
Howdy....I've got an HD700 bought used from Alan Gouger several years ago. Has 2000+ total hours with approximately 200 hours on the tubes that Alan had replaced by Dwin. At the time I wanted to have a crt forever Smile
I tested it out before I stored it in a closet and it worked fine.
When my HDP500 started getting too dim a few months ago , I hooked up the HD700 and have a very good picture except, intermittently, every time I use it, at some point the picture size will become larger, loose geometry and pulse and wiggle a bit. If I turn it off and back on, it will go back to normal and may stay that way for 2 or 3 hours.
I use it as a tv and watch movies and hd sports on a digital pj. I like it as a tv cause I can fall asleep on the sofa and leave it on for hours not care.
Any ideas what the problem is?
Also, if anyone would like to have it for a small fee plus shipping, that's possible too.
Thanks, Hess
Posted: Sun May 27, 2012 4:17 pm    Post subject:
Power supply problems most likely. I can fix it for $250 incl return shipping. Let me know if you want to end it in.
