corrosion on contacts
bengalfan
Posted: Mon May 14, 2012 1:38 pm    Post subject: corrosion on contacts
I just moved into a furnished home in St. John USVI. Very Happy
I went to connect to the TV's & projector here for blu-ray and games and found all the contacts are corroded badly. Sad
Only connection is the cable box, which apparently has never been removed.
Can't find any emery cloth so far, but did try sanding down with a small emery board.... not good enough.
Any suggestions??
Van
The only easy day is yesterday
Posted: Mon May 14, 2012 1:47 pm    Post subject:
Caig contact cleaner should do it... maybe.
Posted: Mon May 14, 2012 1:49 pm    Post subject:
Hello
Salt air, not good.
