Help for Barco Cinemax
Decibel
Posted: Tue Mar 27, 2012 11:39 pm    Post subject: Help for Barco Cinemax
Someone can help for a Cinemax?
A my friend have this projector.
Does not work the adjustment of the sides (bow and keystone).
Any suggestions?
Domenico (Barco fan!)
Posted: Wed Mar 28, 2012 12:32 am    Post subject:
Do the geometry controls work otherwise? Do the R and B convergence zones work in coarse and fine modes?
Decibel
Posted: Wed Mar 28, 2012 7:23 am    Post subject:
I will check the menu convergence today.
This projector had a bad controller. Now it have another controller pulled from Reality 909.
A technician reprogrammed the firmware because it did not work with firmware 909.
Unfortunately I do not know if this version of firmware is compatible with Cinemax.
Here there are two 9": a Reality 909 and Cinemax.
I watched the two "convergence tray" and they appear completely different!
arbey
Posted: Wed Mar 28, 2012 8:47 am    Post subject:
hi
when you try this, do you see I2C error messages on the screen?
crttime
Posted: Wed Mar 28, 2012 1:57 pm    Post subject:
THere are indeed at least two types of convergence boards. Most likely the controller blew the convergence board. I can repair your convergence board.
Decibel
Posted: Thu Mar 29, 2012 6:46 pm    Post subject:
arbey wrote:
hi
No error messages.
Decibel
Posted: Thu Apr 05, 2012 2:23 pm    Post subject:
We tried to swap another (working) convergence output ... no fix problem!
Posted: Thu Apr 05, 2012 2:26 pm    Post subject:
You need to swap the controller AND the convergence board at the same time. If not, try swapping the V board.
Decibel
Posted: Thu Apr 05, 2012 2:41 pm    Post subject:
Thank you Curt
The swap of the vertical board (from a BR909) was the first thing we tried.
The projector has shown an "ic" error.
