Marquee 8000 serial control oddness
fuzzybee
Posted: Thu Mar 22, 2012 3:32 am    Post subject: Marquee 8000 serial control oddness
For some reason, I can't control my 8000 (v2.0) over it's com port. I've tried sending serial strings - nothing. I tried the Marquee Control software from here, and it indicated the projector wasn't communicating. I verified that the baud rate is, indeed, 9600, and the projector is set to ID 001.
Here's the odd thing - I plugged into the switcher port, and I suddenly control everything - except power on. Does this sound right?
On a related note, I have a controllable power relay inline before the projector. Would there be any problem with just setting the projector to auto-power-on, and kill the relay to turn it off?
Posted: Thu Mar 22, 2012 11:04 am    Post subject:
I had difficulties withserial controll when I had a marquee 7500...
You can use the auto power fuction that is why it is there Smile
Posted: Thu Mar 22, 2012 7:06 pm    Post subject:
What are you using for a serial to USB adaptor?
fuzzybee
Posted: Thu Mar 22, 2012 7:07 pm    Post subject:
I have a Prolific device for my USB -> serial, but it doesn't work from my AMX master, either.
If it's no problem to just hard power it off and on, I'll just stick to that method.
Posted: Thu Mar 22, 2012 7:09 pm    Post subject:
Yep thats the issue, prolific doesnt work well for all functions, and it sucks for CalMan as well. You need a Keyspan version. It uses the FTDI chip set.
Posted: Thu Mar 22, 2012 8:02 pm    Post subject:
Hello
Marquee On/Off and Standby commands require more pulses to be read, a second or longer.
fuzzybee
Posted: Thu Mar 22, 2012 8:03 pm    Post subject:
I'll probably just end up cutting the power.
fuzzybee
Tim in Phoenix wrote:
Hello
You're thinking of IR, not serial control, right?
mc86
Posted: Thu Mar 22, 2012 8:12 pm    Post subject:
I can't say I know with the Marquees, but I can say ALL MANNER of my engineering lab equipment using serial communications get mad if I don't have a USB to serial that has the FTDI chipset. I use the UT-882. Specs PDF via usconverters.com is here. Things do weird, partial communications with the ones I tried before OR didn't work at all...wonky, at the very least...
Matt
Posted: Thu Mar 22, 2012 9:06 pm    Post subject:
I agree with Matt, Even my Lumagens do not like the Prolific chip sets. FTDI Chips set never give me any problems.
Posted: Thu Mar 22, 2012 10:04 pm    Post subject:
That's why I use an oooold pentium 1 laptop with genuine serial port for precious things Very Happy
