Got a new hum problem - Need tech experience!
Boilermaker
Posted: Sun Mar 18, 2012 11:59 am    Post subject: Got a new hum problem - Need tech experience!
A week ago a loud hum appeared on all channels of my HT audio system. I made no changes to cause it and it just appeared. In chasing down the problem I found it went away as soon as I disconnected the CATV line to my cable box. So I picked up a little CATV in-line hum eliminator and the hum disappeared.
The new problem I discovered Friday was that one of the channels (NCAA BB game) would not work. In fact, it was only one channel that would not work. So, I removed the hum eliminator, and the channel now works! WTF!!!
I assumed the hum eliminator is nothing but a series capacitor to block the low frequencies, but am I missing something here?
Bob
HK-Steve
Posted: Sun Mar 18, 2012 12:05 pm    Post subject:
I had the same kind of problem,
I went to an car audio shop, picked up a stereo line isolator, has RCA plugs on each side. Solved my issue.
Something like the ebay link.
http://www.ebay.com/itm/Scosche-ES034-RCA-Ground-Loop-Isolator-Amp-Stereo-Signal-Noise-Filter-Suppressor-/120878069517?pt=LH_DefaultDomain_0&hash=item1c24e4f70d&vxp=mtr
Cheers
Boilermaker
Posted: Sun Mar 18, 2012 12:17 pm    Post subject:
Was your problem caused by a CATV signal?
HK-Steve
Posted: Sun Mar 18, 2012 12:21 pm    Post subject:
Yes it was, same issue of hum when connected, gone when dis-connected.
The output from my sat box is just stereo rca jacks, so was an easy fix.
Cheers
Steev
Boilermaker
Posted: Sun Mar 18, 2012 12:49 pm    Post subject:
I'm using both the Toslink and the analog outputs for two different rooms, so I'm going to to disconnect the analog outputs to see it that will work.
Bob
Posted: Sun Mar 18, 2012 12:56 pm    Post subject:
If not, try a different brand of cable ground isolator. All are NOT made the same!
Posted: Sun Mar 18, 2012 12:59 pm    Post subject:
Also, if the AC plug is 3 prong, try a 2 prong adapter.
Boilermaker
Posted: Sun Mar 18, 2012 1:54 pm    Post subject:
Pulling out the analog didn't help - What is really wierd is that there is no hum in the analog system I'm using in my bedroom, but it is in my HT which is using the toslink!? All the equipment is located in the same rack, however.
Good idea - Jensen used to make stuff like this years ago, so I'll try to find them.
It's only two.
I hate cable - I should reactivate my Directv as it is much nicer. I went with cable because they bundle it with phone and internet and it's hard to beat the price.
Bob
Posted: Mon Mar 19, 2012 11:45 am    Post subject:
No, don't use the consumer stuff. Go to a satellite installer and ask to buy one. Worst case, I've got them here, but you should be able to get one locally. Look for something like the Holland brand, Blonder Tongue, etc.
Posted: Mon Mar 19, 2012 12:13 pm    Post subject:
Bob, Where is the distribution box/splitter for the cable Grounded? If its not grounded to the same side of your isolation transformer as the rest of your system a hum can develop. I had the same issue with my Sat box. I then ran a ground from the distribution amps for the sat dish's to the sub panel box and the hum went away. Might be the same thing.
Boilermaker
Posted: Mon Mar 19, 2012 1:56 pm    Post subject:
Hadn't thought of that - Easy to do, so I'll do it.
Actually got lucky on this one. When the cable guy came out I insisted that he exchange my box for a newer one with a decent sized hard drive. The hum is now gone - must have been something wrong with the old box?!
Posted: Mon Mar 19, 2012 3:40 pm    Post subject:
Probably not. Ground loops can occur when changes are made somewhere in the cable line outside of the house, down the road or across the street somewhere. Different units route the ground differently as well, so it can change for the better or worse when the box is changed. Change the preamp or something in your a/v system, and that too can make it better or worse.
Boilermaker
Posted: Mon Mar 19, 2012 5:05 pm    Post subject:
Ground loops can be a major PITA to find. The more complex the system, the more opportunity for a loop to occur, and mine is very complex. I'm just glad that this one is gone and I can still get all the channels.
I wish someone made an inexpensive converter that would convert the coax CATV to optical and then back to coax which would eliminate this problem and also eliminate lightning damage to equipment coming in on the coax.
Bob
