It is possible to run a G70 with a universal remote
SGIforever
Posted: Sun Mar 11, 2012 8:36 am    Post subject: It is possible to run a G70 with a universal remote
I have found an interesting deal on a Sony VPH-G70, however the original remote is missing.
The seller says he have been using a Philips universal Pronto remote and it has worked fine.
I have searched the forum for people with similar problems, and it seems like most people have
managed to find a proper remote through 'Buy and Sell' or otherwise, which solved their problem.
So, how good can a universal remote be with a G70?
I guess basic operations could work fine, but how about setup functions. Does it come down to
how well the remote is programmed?
Can setup procedure be done without a proper remote?
/B
Posted: Sun Mar 11, 2012 8:58 am    Post subject:
How could one lose such a device?? This is what i want to know!!
Do these projectors have PC control like the NECs do?
AFryia
Posted: Sun Mar 11, 2012 2:35 pm    Post subject:
I've only ever had Pronto remotes for my G70.
Pronto NEO and the TS3000.
I preferred the NEO for setting up and convergence. The form factor was better for holding with a single hand. And the response seemed a little quicker.
But the NEO died so I'm now using the TS3000. Works fine.
My Volt Blog
rosenbush
Posted: Sun Mar 11, 2012 4:05 pm    Post subject: Pronto 1000
You can get a Pronto 1000 really cheap and download the commands for the G70:
http://files.remotecentral.com/view/5404-13085-1/sony_vph-g70_projector.html
Posted: Sun Mar 11, 2012 4:30 pm    Post subject:
Personally I would never want to setup a Sony without the original remote. I would go nuts trying to use a Pronto or something like that for a setup. A Pronto would be fine for daily use, but setting up would be a nightmare to me.
Curt may have remotes and I do have them in stock. I have wired only and IR+wired G70 remotes. The wired only remotes are cheap too.
Posted: Mon Mar 12, 2012 2:36 am    Post subject:
I am out for now, since a few of my G90s came without remotes, so feel free to sell one, Craig.
Posted: Mon Mar 12, 2012 3:27 am    Post subject:
Let me know if you need any Curt.
Posted: Mon Mar 12, 2012 3:31 am    Post subject:
Will do, thanks! I think I have just enough, including one spare for the bench, but if someone buys all of the 10 G70s I have here, I'll be in trouble. Smile (All G70s have tube wear!)
SGIforever
Posted: Mon Mar 19, 2012 4:28 pm    Post subject:
So it is quite possible to run a G70 with a Pronto remote, also the more advanced functions,
even if some prefer the original one.
I didn't know you could download stuff like that for the remote. Cool.
Since there is a possibility to get an original remote, and make the PJ complete, I think
I will try to get one anyway.
Thank you for insights.
AFryia
Posted: Mon Mar 19, 2012 10:15 pm    Post subject:
Absolutely!
I've setup my G70 numerous times with two different Pronto remotes. I don't know of any buttons found on the original that can't be programmed into or learned by the Pronto or similar remotes.
SGIforever
Posted: Tue Mar 20, 2012 8:32 pm    Post subject:
Unfortunately someone else got the G70 because of my indecisiveness.
I suppose I missed a good deal.
Only a few hundred hours on new tubes (allegedly). Old tubes included
Well, there will be others (A NEC XG has shown up Smile)
