Barco 1209s/E raster width (think that is the problem)
nombz
Posted: Sat Mar 10, 2012 6:44 pm    Post subject: Barco 1209s/E raster width (think that is the problem)
I am trying to go to 72Hz 1080p with my BarcoGraphics 1209s/E.
I am using a HTPC with Powerstrip so I have full control (does not mean I know exactly what I am doing Smile ) of porches etc.
For 1080p 48Hz I have been able to get a full screen (with good phospor usage) but now when I step up to 72Hz I cannot really get the picture to fill the screen. I am guessing it is the raster width that is to narrow and I believe that because of two reasons (hope I am right)
1) When I increase blanking from the left, I immediately start to impact the actual picture.
2) When I adjust the phase, the picture disappears behind a "invisible edge" to the left.
Am I right in assuming that my problem is the raster width?
I read that I might need to adjust a pot somewhere to increase the raster width for higher frequencies, how do I know that I am using the high frequency "functionality"?
What would be reasonable porches to have for 1080p72Hz? I have tried between 6 and 120 for front porch and about the same for back porch, but still cannot get the picture fully to the left.
BarcoGraphics 1208s/2 and BarcoGraphics 1209s/E
opv
Posted: Sun Mar 11, 2012 9:12 am    Post subject:
Is your H-width set to 100?
If the answer is no, then turn it up and see if that solves the problem.
If the answer is yes, the problem might be the raster width, but I suggest you play with the porches first before you change the raster width.
nombz
Posted: Sun Mar 11, 2012 10:44 am    Post subject:
Well, 99 but that is as high as it goes.
But the porches only affects the picure on the raster, not the raster itself, right?
I read up in the service manual and I can see that there is indeed two modes and a LED to see which one is used.
Unfortunately it looks from the service manual that there is two coils per color used for both high and low scan mode, but they change from being connected in series to parallell when the modes change. This means that if I start playing with these it will affect both modes and that means I have to be more sure on what I want to do since it will potentially mess up the current setup I have (with 1080p 48Hz).
Is this right? Adjusting one coil will affect both modes?
opv
Posted: Sun Mar 11, 2012 12:01 pm    Post subject:
In my 1209s, I adjust the picture width of all the colors together using the H/width pot on the SMPS, not separate ones per color.
nombz
Posted: Sun Mar 11, 2012 12:09 pm    Post subject:
Aha, Ill have to look into that aswell, thanks for the idea. Adjusting the coils (per color) seems more like an adjustment to get the raster the same width for each color. Your idea makes much more sens, one pot for all three and then if needed adjusting the individual raster to match up.
Thanks!
Ile
Posted: Sun Mar 11, 2012 1:50 pm    Post subject:
Sounds too small horizontal porches to me. Porches add unused area to rasters edges, actual picture is leaved as is.
I used these 1080p72 timings in my BG1200.
Horizontal
Front porch 140
Sync width 100
Back porch 240
Vertical
Front porch 10
Sync width 10
Back porch 40
You can also try smaller horizontal back porch, but it could cause raster ringing (vertical bars) to left side of the picture.
First adjust Hwidth so that you can see whole raster. Then adjust Hphase so that actual picture is pretty close to right edge of the raster. Then center actual picture to tubes and adjust Hwidth. Now if you can't fill tubes with actual picture you need to trim master width pot from smps doughter board.
Raster width coils adjust more horizontal linearity than rasters width with high resolutions. Those are pretty useless, I have actually thought about removing those to see if that helps to get rid of raster ringing. Very Happy Then back porch could be reduced and that means less stress for horizontal deflection and also bit sharper picture.
nombz
Posted: Sun Mar 11, 2012 3:34 pm    Post subject:
Horizontal
Front porch 140
Sync width 100
Back porch 240
Vertical
Front porch 10
Sync width 10
Back porch 40
Thanks for your input Ile, much appreciated!
I am now 100% sure this "issue" is caused by the raster not being wide enough. If I adjust brightness to 60 and contrast to 10 I can easily see that my picture is filling the raster fully (and when I decrease Hsize I can see the raster on each side of the picture).
Again, change porches will not change the raster, right? It will only change the picture position within the raster?
The master width pot on the SMPS daughter card affects the width of the raster, right (not the picture, direcly)? I can see that I am not too far from the edge of the phosphor like it is today but I still have... like 1cm from the edge on the closest place on the closest tube with the raster.
When I am running lower frequencies the raster is then bigger which I wasnt aware of. If I switch back to 1080p48Hz and turn contrast down and brightness up I can see that the raster size is actually a little, little bit outside the phosphor edge in one corner. Is this "expected"? If I adjust the master pot that would mean I get a wider raster for lower frequencies aswell and will be going over the phosphor edge. Is that a problem? (I am of course making sure that my picture is within the phosphor edges to avoid... interesting problems).
secstate
Posted: Sun Mar 11, 2012 5:08 pm    Post subject:
In my experience later Barco 120x series have issues with horizontal width size at higher resolutions and refresh rates. The two solutions I have found are. One if a Graphics (versus Data) you can adjust the cut over to the high scan mode this solves the width problem but at least on my 1208s/2 Graphics introduced some pretty severe ringing on the left side of the screen. Two, bring the electronic width adjustment down some what from max (say 85 or 90) and adjust the horizontal width pot on the SMPS to fill up the screen. Note that the potential issue with number two is that some of the 120x S series Barcos had an issue in the SMPS that would cause the horizontal instability which is seen as a brief collapse of the horizontal width (almost like a blink) and this is made worse as you push the width with that pot. Hopefully your /E is new enough it does not have this issue (it was corrected fairly late in the model run). I think Curt has the TSB for this issue on his side under the 120x documents.
I have a Runco 1209s Data clone and so I don't have high scan so I use option two. My Runco manufactured in May 2000 has the fixed SMPS and I have done option two and it works perfectly.
nombz
Posted: Sun Mar 11, 2012 7:05 pm    Post subject:
Thanks for those options!
I definitively have the ringing issue already with 1080p48Hz. Maybe a solution would be to reduce the threshold for "high scan mode" to make sure that 1080p48Hz and 1080p72Hz is within the same mode (high) and then adjust the SMPS raster width to work with that?
nombz
Posted: Sun Mar 11, 2012 8:21 pm    Post subject:
So now I have adjusted the P2 and actually set it to max. This means that with a Hsize of about 80 I can fill the screen (and keep the picture of the phosphor edge) nicely.
Now all I need to do is go through the electronic setup again (well, to be honset I have needed to touch convergence etc for probably 2 years now, this thing is rock stable).
It will be interesting to see what 72Hz will do with the picture. Focus is still very, very good in the middle (without even touching convergence/focus yet, I spent a lot of time getting the physical setup right).
Thanks for your help and I hope I havent done anything stupid in maxing the P2 out? I am very careful to make sure picture is never outside the phosphor.
secstate
Posted: Mon Mar 12, 2012 2:13 am    Post subject:
I got rid of the ringing by making the (front or back, cannot recall which now) porches larger with power strip and using h-phase to bring the image back to center. That allowed me to shift the image away from where the ringing occurred on the raster.
Ile
Posted: Mon Mar 12, 2012 12:32 pm    Post subject:
Porches and active picture determine raster size, so porches will chance raster. Porches are that unused raster area you will see when you elevate brightness.
No, if you add pixels to porches that will make raster bigger.
If you move 50 pixel from back porch to front porch, this keeps raster size same but picture moves along raster. This have same effect that using projectors Hphase setting.
Yes, it affect to raster width.
It's better to adjust Hsize using highest resolution you use and then set Hsize to 95 from menu and then use trim pot to set correct width.
And yes activating "high scanning mode" is first thing to do when setting up 1080p to 120* series.
nombz
Posted: Mon Mar 12, 2012 5:05 pm    Post subject:
Thanks a lot Ile!
I was pretty sure raster width was not affected by porches but there you go, you learn something every day Smile
So what I should really do is make sure I have a resolution with the porches I want (along the lines you recommended) before I set Hsize to 95 and adjust the master width pot. From my understanding small porches are good as long as you dont run into the ringing on the left side (which I definitely had with my 1080p48Hz setup).
I tried the porches you recommended but it looks like I got into problem somewhere in my digital chain because I got strange red lines that looked pretty much like stuff I seen when using a too long HDMI cable. Probably because I reached a too high bandwidth. Which part of my chain is creating these effects I dont know. I have a HTPC with DVI-HDMI cable (3m long) to a HDFury 3 and from there the short cable to input 5 (but I am pretty sure the problems are on the digital side).
Ile
Posted: Tue Mar 13, 2012 10:09 am    Post subject:
Correct.
Fury3 maximum pixel clock should be 225Mhz, so that shouldn't be problem since 1080p72 with those timings is around 200Mhz. Maybe that is too much for that 3m hdmi cable, try with shorter one if possible or reduce horizontal back porch to see if that helps.
I used those timings with vga output.
nombz
Posted: Tue Mar 13, 2012 7:16 pm    Post subject:
I have played around some more and I do not really see that I have ringing (which is vertical "lines" to the left) even though I am using much smaller porches than you.
My problem is really that to the left I seem to have what I am guessing is phenomena related to controling the beam. Horizontal lines are slightly wavy (more the more to the left you look). I seem to remember Guy Kuo at some point said something about the beam needed "time" to be stable. I think that is what I might be seeing.
If I rastershift the raster to the left and then hphase the picture to the right it is much reduced. From the discussions here and your input Ile I guess I should really be able to do that type of adjustment with front and back porches. My theory was that if I have more front porch that should push the picture to the right, but I cannot really get that into practice.
I have done as recommended and adjusted the master width pot while having Hsize set to 95. I guess that means I am somewhat "safer" with new settings (although I will not use almost anything else than 1080p72 from now on).
BTW, I cant believe how well the 1209s/E maintains focus in 72hz, I feel like I have lost some serious movietime in using 48Hz. Motion is much "smoother" (but that it not really what is it) and picture more stable. But I do not think I have lost any focus at all. Really love it so far!
Ile
Posted: Wed Mar 14, 2012 8:53 am    Post subject:
That wavyness is also called raster ringing, those waves at beginning of the scan forms "vertical bars" to left edge of picture when you have proper material. IRE60-70 fields show that problem best.
Yes, this reduce problem, because then beam have more time to stabilize before actual picture starts.
It doesn't matter are you using Hphase or altering porches to move picture to right when there is enough porch wide.
That's because back porch is actually before actual picture and front porch is after it.
Those names are referring porch position to horizontal sync.
So you should increase back porch to get more unused space before actual picture. Thumbs Up
nombz
Posted: Wed Mar 14, 2012 10:12 am    Post subject:
Ahhhh, thats a good gotcha. No wonder I couldnt get it straight. And it also explains why you recommended increasing the backporch to reduce ringing Smile
Thanks a lot Ile, much appreciated!
nombz
Posted: Tue Mar 27, 2012 7:25 pm    Post subject:
Just as a follow-up on this one (if anyone except me cares:) ).
I was able to get the 1920x1080x72Hz with the Hdfury 3 but with the timings much shorter than suggested here.
However, since the digital path (unclear to me what, but looks like the hdfury3 is causing this) wasnt able to handle 1920x1080x72Hz without obvious problems (red lines appearing random across the screen) I was encoured to try using VGA.
With VGA I use timings much larger and more like the once recommended here.
Notice my surprise when I saw how much better and stable the picture was using VGA than the hdfury 3 (that is really another story that I hope the hdfury guys can help me answer on that forum http://dme.ghost2.net/forum/viewtopic.php?t=25474&start=0&postdays=0&postorder=asc&highlight=). The image is now... truly stunning.
Removing the hdfury(I have been using nothing but hdfury instead of VGA since before hdfury got its name...) and going to 72Hz is as much upgrade for as it was going from the 1208s to the colorfiltered 1209s. A pretty big and very apparent difference.
