Motobias
Joined: 08 Jul 2008 Posts: 163 Location: Osnabrueck, Germany
| Posted: Mon Feb 20, 2012 10:52 pm Post subject: Barco Graphics 808 weird problem with projection orientation |
Yesterday im picked up a dirt cheap 808 which was dead when i got it and looked horrible from the outside.
Anyway...took the set home and tubes are brilliant i would rate at least 8-9, 2300h on the set !
i had to change the smps fuse and the replace the g2 board because it kept shutting the unit off after a few seconds.
g2 board from my other 808 brought it back to life and it was doing fine.
adjusted g2 voltages and 17v reference and kept it running for an hour with computer attached to it playing videos.
then i thought i should add convergence...and first change it from front ceiling to front table mode - then the trouble started !
setting the single switch for ceiling/table made the set power up but not bringing up the status screen, also locking all remote controls and bringing up a rcu error - wtf ?!?
setting the switch back, everything was fine...
then i changed the front/back switches...same problem - wtf ?!?
operated the switches a couple of times - did not change a thing !
then i got myself pcb cleaner and sprayed the switches, waited couple of minutes and cleaned them out with compressed air.
that transported the cleaner AND some murky liquid out of the switches... smelled like rotten water and wouldn't evaporate...
so it can only be WATER ?!
everything else in the set is looking fine and there is no clear evidence that the set has been sitting outside and/or that it got moisture inside !
i think the switches are gone or badly corroded, causing the error in the controller but can't really verify that.
has anyone ever had a similar problem and/or got it fixed somehow ?
how are the pins laid out, so i can check the continuity of the switches and their resistance ?
is there a way to unsolder the switches without taking the main pcb out of the unit(opening the bottom) ?
got some pictures of the set...not the actual problem
at the very bottom...
http://www.facebook.com/media/set/?set=a.10150403825268502.446567.738343501&type=3&l=f1324298fa
all help appreciated
Ile
| Posted: Tue Feb 21, 2012 10:48 am Post subject: Re: Barco Graphics 808 weird problem with projection orienta |
| Motobias wrote: | has anyone ever had a similar problem and/or got it fixed somehow ?
is there a way to unsolder the switches without taking the main pcb out of the unit(opening the bottom) ? |
My BG808s frame board switch have cracked plastic housing and spring got out, so it need little tweaking to get it to right position. I have though that I will remove it and solder jump wires if it get worst, haven't checked switch pin out.
Frame board can be pulled out from back after all back end cards, back panel, plastic side panels, ir receiver, quad and frames side screws are removed.
Motobias
| Posted: Tue Feb 21, 2012 1:26 pm Post subject: |
hmm...cleaned switches as good as possible from the top...because getting the main pcb out will be a pain in the ass and i hope i don't have to ! (includes unsoldering wires - pretty sure about that)
checked for bad solder joints on deflection boards and cleaned contacts aswell...nothing !
weird thing is that either front/back or ceiling/table will cause the same problem and i think that at least the single multi contact switch for ceiling/table should be good...
could it be a firmware issue ?
_________________ Most peope talk about HD without knowing the meaning and how to do it RIGHT !
FIGHTING STUPIDITY SINCE 1983
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Tue Feb 21, 2012 1:41 pm Post subject: |
You could replace the frame (motherboard) because could be bad a reverse scan switch, but the disassemble motherboard is very difficult.
So if you have another 808 ... swap all better boards and better tubes into this other chassis and try.
I had a reverse scan switch bad in a my projector and it was impossible to found.
| Description: |
| Filesize: |
16.36 KB |
| Viewed: |
7607 Time(s) |
_________________ Domenico (Barco fan!)
Motobias
| Posted: Wed Feb 22, 2012 1:38 pm Post subject: |
ok the switches seem to be alright...
they are pulling either hsi or vsi on the controller to ground
in my working configuration (front/ceiling) hsi is pulled down and vsi is up.
if i change either horizontal or vertikal i am getting the error!
hsi vsi
down up WORKING
up up ERROR
down down ERROR
up down ERROR
ERRRRRRRRR !!!!
i am thinking about just setting the switches and cut/short the cables according to my needs...but that's not the way !!!
so am i facing a controller problem ? maybe the diodes next to the pin headers ?!
i am getting a second controller beginning of next week and will try that...
Decibel
| Posted: Wed Feb 22, 2012 2:43 pm Post subject: |
There are four switches.
This is the positioning for the different mounting configurations
| Description: |
| Filesize: |
48.98 KB |
| Viewed: |
7573 Time(s) |
Motobias
| Posted: Wed Feb 22, 2012 6:07 pm Post subject: |
aaaaaaaaaaah i'm not stupid !
JEEEEEEEZEEEZ
Motobias
| Posted: Wed Feb 22, 2012 6:19 pm Post subject: |
vsi and hsi end up on the 80c32 standby processor... can this one go bad ?
maybe i changed a switch without making sure that the standby voltage was completely gone or off...
CUUUURT help me in my misery !
barclay66
| Posted: Wed Feb 22, 2012 6:37 pm Post subject: |
I know that such a problem can be PITA. Nevertheless I would suggest that You stop for the moment and wait for the controller You're getting next week. By swapping it You could rule out a lot of potential problems at the same time. And You could make things worse in the meantime. In fact, I think that the controller is the least probable cause.
If You take a look at the Frame schematics You will see that the switches are directly connected between the H-Deflection / V-Deflection Boards and the Deflection Yoke connectors. They are used to switch the polarity of the Deflection signals as needed. So we can expect that the entire Deflection current will go across them and that can be a significant amount of current (even soldered yoke connections or plugs sometimes simply burn away). Any kind of contact weakness will most likely result in contact burn and additional failures.
I have a complete Barco Graphics 808 in parts (I took apart a set with dead tubes). So if You need some measurements for comparision or even the complete Frame I could be of help.
BTW: No soldering is needed in order to swap a Frame as long as You swap the HV-Splitter together with it!
Regards,
barclay66
Motobias
| Posted: Wed Feb 22, 2012 11:37 pm Post subject: |
oh yes...it is a PITA
the switch contacts for the deflection yokes seem to be alright and won't cause such a problem...unless they cause a scan fail signal, but that on the other hand would cause a different behaviour !
where are you located in germany ?
crt owners need to stick together
barclay66
| Posted: Thu Feb 23, 2012 10:38 am Post subject: |
| Motobias wrote: | where are you located in germany ?
crt owners need to stick together  |
Yes they have to. I'm near Munich so almost as far away as You can get from Your place...
Regards,
barclay66
Decibel
| Posted: Thu Feb 23, 2012 5:42 pm Post subject: |
| Motobias wrote: | aaaaaaaaaaah i'm not stupid !
JEEEEEEEZEEEZ |
I don't think that you're stupid. I try to help you.
But sometime the issue is stupid!
When someone of us fix it, says "I'm so stupid, why I don't think before?"
So ... have you checked with meter the pins of the switches and the effect on pcb?
There are two positions that select alternatively the two rows of pins like picture.
| Description: |
| Filesize: |
11.32 KB |
| Viewed: |
7503 Time(s) |
Motobias
| Posted: Thu Feb 23, 2012 7:07 pm Post subject: |
here's what i found
| Description: |
| Filesize: |
99.58 KB |
| Viewed: |
7490 Time(s) |
Motobias
| Posted: Wed Sep 26, 2012 7:39 pm Post subject: |
ok...i must admit i haven't tried harder so far.
today i damaged my little finger with an angle grinder, so i get to think about this issue a bit more.
as i can not access the projector atm and i only have a second faulty controller, it's all about clever ideas now
i think i will cut the cable that tell the controller how the switches are set and see what it does.
of course it won't have the right information about where left/right and up/down is, but it might fix the problem that the projector will not start up.
if this fixes it, the according chip on the controller is bad, or the controller screwed alltogether !
my first bg808 will serve as a donation device anyway, as the green is to bad to use... or in case the mainboard is bad, i'll switch over the green tube and all good boards into it...but if the cotroller is bad, i am back where is started.
i still have my xg135 which will be the first choice to put in, the green tube is my only concern !
| Posted: Wed Sep 26, 2012 9:41 pm Post subject: |
The question is why is it important for the controller board how is it mounted? For example on my PG xtra I have to set in the menu how the pj is mounted, but that is only affects the astig drive, every other connector needed to be set manually for the right operation, all yoke have a two pin connector so from projector side there is no way to find out how are the yokes connected. I think your idea should work, the only thing you have to find out is which functions are inverted by software (like the astig in the case of NEC), if you find them you have to reverse those corresponding yokes and that's all.
Is a new controller board expensive?
| Posted: Thu Sep 27, 2012 3:53 am Post subject: Re: Barco Graphics 808 weird problem with projection orienta |
| Ile wrote: | | Motobias wrote: | has anyone ever had a similar problem and/or got it fixed somehow ?
Frame board can be pulled out from back after all back end cards, back panel, plastic side panels, ir receiver, quad and frames side screws are removed. |
No so easy as certain wires which are looped under the frame will hit the chassis when you attempt to slide out. The only way to dismantle without damage is to remove the sides first.
| Posted: Fri Sep 28, 2012 3:14 am Post subject: |
Yes, I have had a controller board bad in an old BG800 many years ago. It wouldn't work with the V scan switch in one position because of that one wire that connects to the control board. I spent hours trying to figure it out back then.
I would change the controller board. I've got them at $50 plus about $20 shipping, but I'm out of town until Oct 18.
Motobias
| Posted: Wed Nov 21, 2012 5:23 pm Post subject: |
ok...it's the controller !
switched the controller over into another 808 with short in controller board and tried to fire it up - same problem !
set the switches accordingly and it came right up...
changed eeproms over, works but same issue.
so somehow the controller is bad...
now i am stuck with two dead graphics 808
one dead controller, another one with this issue and one bad smps !
any suggestions on how to repair a shorted controller ?
anyone got circuit diagrams for the controller ?
Motobias
| Posted: Thu Nov 22, 2012 3:14 pm Post subject: |
i just cut the hsi and vsi cable to the controller and set the switches for front/table.
weird thing is that the software somehow senses it right but then of course mixes up top/bottom and left/right
well at least it's working now...somehow
i blew another smps aswell and it's now just blowing every main input fuse - damn !
not that much luck with barcos, but i am still trying
