Jeremy112
| Posted: Sun Feb 19, 2012 1:08 am Post subject: My Pearl took a dump :\ |
So yeah.. score count: CRT 3, Digital 0
My Sony VPL-VW50 "pearl" has somewhat died. The bulb will not spark, and its not the bulb, I have 2 confirmed good ones and all I get after it attempts to ignite the lamp is the red "Lamp/cover" LED blinking
Sooooo..... Since Im not a digital PJ repair guy, what is the deal? O_o This thing is harder to get into than walmart on black Friday
| Posted: Sun Feb 19, 2012 1:47 am Post subject: |
I getting ready to sign off for the night but is it a 2x blink or a 3x blink?
Jeremy112
| Posted: Sun Feb 19, 2012 2:40 pm Post subject: |
Morning Mac and all Forum goers!
The projector blinks twice for the lamp/cover LED. I have to assume nothing serious went wrong because the fact the day before it stopped working it was working perfect, but that means squat these days
| Posted: Sun Feb 19, 2012 4:45 pm Post subject: |
A 2 blink code is lamp cover or filter cover. Both covers have a switch that should close when the cover is installed. If the covers are properly installed then you will have to test the switches with you DMM to make sure they read closed.
Jeremy112
| Posted: Mon Feb 20, 2012 3:07 pm Post subject: |
Mac,
I checked the switches with the DMM, they do read closed, and the covers go on nice as well. So unfortunately that wasn't it.
Id have had my CRT going by now if it had problems, damn digis
| Posted: Mon Feb 20, 2012 3:30 pm Post subject: |
It's definitely the LAMP/COVER LED that's blinking and it's definitely 2 blinks?
Jeremy112
| Posted: Mon Feb 20, 2012 4:21 pm Post subject: |
| macgyver655 wrote: | | It's definitely the LAMP/COVER LED that's blinking and it's definitely 2 blinks? |
Yep mac, it IS the Lamp/Cover LED. It blinks red twice, pause, blinks twice, pause, etc etc etc.
I can recheck the switches with the DMM if I have to, it just seems like a simple issue because the night it worked, I turned it off, no issues whatsoever, the next day I went to use it this issue happened. The PJ didnt get bumped or anything...
Dammit Sony, what the hell is wrong with you?
| Posted: Mon Feb 20, 2012 4:23 pm Post subject: |
Are you looking to trouble shoot then?
Jeremy112
| Posted: Mon Feb 20, 2012 4:54 pm Post subject: |
If possible mac, Id like to get it fixed, I WOULD like to keep it so it would be nice to get fixed anyway.
Okay heres an update, the projector NOW blinks 3 times... SO I will try the other bulb once. I noticed the switch for the filter cover is a finnicky one as far as the cover itself goes, but I know it was on correctly.
For chills and thrills Ill try the other bulb anyway and see wht happens, but as I said before, it blinked only twice, and now doing 3 times.
Update to come shortly
Jeremy112
| Posted: Mon Feb 20, 2012 5:05 pm Post subject: |
Okay, it blinks 3 times still with the other bulb, so it may have always blinked 3 times, I cannot be sure since its only one extra blink for a completely different issue....
Anyway, sorry mac, it was THREE blinks *My bad* with either bulb, so yes if you are offering assistance I would be very greatful
| Posted: Mon Feb 20, 2012 5:55 pm Post subject: |
3 blinks is lamp or lamp ballast.
First thing to check is for DC voltage at CN301 on the GA board. This would be a 2 wire harness going to the ballast. You can check it at the ballast if it's easier. It should be around 330v to 385v. Use caution when working around the ballast as there are HIGH VOLTAGES. Your better off connecting jumper wires to your DMM while the projector is off and unplugged, then turn it on to get your readings. Make sure lamp is installed and all covers are in place.
Jeremy112
| Posted: Mon Feb 20, 2012 6:26 pm Post subject: |
Okay, took me a bit to make sure that I was on CN301, wasnt too hard to visually see the only 2 wire harness there, but anyway,..
With the DMM set to HV so it can read the voltage, I turn the PJ on and the DMM glitches then has random readings, glitches, then it goes up to 390V steady while the green Lamp/Cover LED blinks, nothing happens, goes back into standby and blinks 3 times, voltages drop down to nothing.
| Posted: Mon Feb 20, 2012 7:09 pm Post subject: |
Ok, next you need to locate the connector on the ballast with 5 wires. It should be the only other harness connected to it, other then the lamp wires.
You'll need 4 pieces of wire long enough to push into that connector and reach outside the projector to your DMM. Tape 1 end of each wire to a piece of card board. Mark on the cardboard pin1, 2, 3 and 4. This is where you will be testing with your DMM. Then push the other end of each wire into that connector accordingly for pin1 , 2 and so on. You will not be testing pin 5 on that connector.
Now connect your DMM gnd to the pin 2 wire and set it to DC. Now connect the pos probe to pin 1 and start the projector and record the reading before it goes into shut down. Then test pin 3 on startup , and then pin 4 on startup.
Let me know your readings.
Jeremy112
| Posted: Mon Feb 20, 2012 11:36 pm Post subject: |
Mac, sorry I havent gotten back to you, I just got my Sansui G-4700 in and I started working on that (Mainly because it will be making me some $$$) Its almost done so Im going to go ahead and test those points on the PJ tonight and post back for you.
Just didnt want you waiting around
| Posted: Mon Feb 20, 2012 11:46 pm Post subject: |
What do Jeremy112, Curt Palme, Tim Martin, Analogrocks and several others here have in common?
HOARDERS!
Jeremy112
| Posted: Tue Feb 21, 2012 12:53 am Post subject: |
| Curt Palme wrote: | What do Jeremy112, Curt Palme, Tim Martin, Analogrocks and several others here have in common?
HOARDERS!  |
NEVER curt I only have about 12000 pounds of electronics/computer equipment so thats not so bad
| Posted: Tue Feb 21, 2012 4:37 am Post subject: |
I'm no hoarder. I'm a collector of multiple pieces of the same thing.
Jeremy112
| Posted: Tue Feb 21, 2012 6:48 pm Post subject: |
Okay.... Never got to the pearl yesterday, mondays are never good around here to do anything I want to do.
Thats what teusdays are for! I am getting the PJ ready for the readings as I type so I will post them shortly
Jeremy112
| Posted: Tue Feb 21, 2012 7:06 pm Post subject: |
Okay,
Pin 1 in standby, during startup, and after shutdown is at 3.30V
Pin 3 is at 3.30V in startup
Pin 4 is at 1.28v on startup
As a side note I envy those who work on digitals, you must have small fingers!
| Posted: Tue Feb 21, 2012 7:30 pm Post subject: |
| Jeremy112 wrote: |
As a side note I envy those who work on digitals, you must have small fingers!  |
When it comes to digitals I usually only use my middle finger........
